  4. Dt125 re not charging battary
22 Posts 6 Posters 6.4k Views
  • R Offline
    R Offline
    reecesloane 2017
    Hi can anyone help me with some ideas I've got a dtr that's almost new but been stood a few years I put a new battery on and everything was fine for a couple days then the battery died changed battary for a new one and did same in a couple days I guess it's not charging any common problems I could check thanks
      Nope, charging units on these bikes are pretty solid.
      You will have to do an impedance test against the coils to see whether or not they are faulty.
      • ZrakoZ Offline
        ZrakoZ Offline
        Zrako
        Same here mate . I think its rectifier . I would say test it charged and let it run for few minutes. Im heard if its below 13.2V its bad . Mine is charged like 13.34V and always ends up below 12V 😞
        1979 Jawa Mustang 50
        2003 Gilera DNA 125 R.I.P
        2015 Keeway TX 125 SM
        2006 Yamaha DT 125 X
        • R Offline
          R Offline
          reecesloane 2017
          Tbh j don't even want a battery the bikes pretty much brand new cant see what would be wrong I might just get one of thoes capacitors
            Fix it instead of masking the problems. Get a cheap multimeter, and we will help you out. After that, get a capacitor if you want.
            • R Offline
              R Offline
              reecesloane 2017
              Good plan I'll grab one
              • R Offline
                R Offline
                reecesloane 2017
                Ok got me a multimeter where should I start ? Thanks
                • F Offline
                  F Offline
                  Start the bike, then test the voltage at the battery. You're looking for about 13.5 at idle and 14V with the revs up
                  • R Offline
                    R Offline
                    reecesloane 2017
                    Not good the the battery is flat now engine off is at 3v and started at 5v
                    • R reecesloane 2017
                      @reecesloane-2017 It runs with a flat battery?
                      Must be generating power.
                      • R Offline
                        R Offline
                        reecesloane 2017
                        Yes runs perfectly but brand new battary only lasted a couple days I thought it was the battary took it back and got another and that's done the same now all the lights work when running but doesn't charge the battary
                        • ZrakoZ Offline
                          ZrakoZ Offline
                          Zrako
                          Did you checked all wires and connectors from generator to rectifier?
                          • R Offline
                            R Offline
                            reecesloane 2017
                            Yes all
                            Look pretty good no damage that I can see nothing corroded bikes almost new so abit strange is it possible I'm ising the wrong battary I just got one that had the same dimensions and 12v ect surly it can't be that bad
                            MightymanM 1 Reply Last reply
                              Yes all
                              MightymanM Offline
                              MightymanM Offline
                              @reecesloane-2017 generally, as long as it's a 12v battery it shouldn't make any difference so that isn't your issue.
                              • R Offline
                                R Offline
                                reecesloane 2017
                                That's what I thought I'm stuck now electrics isn't my thing
                                • MightymanM Mightyman
                                  @Mightyman little bit more to it than that bud. Obviously needs to be rated appropriately otherwise the engine will drain more power from the battery than the battery can supply. But the DT's could probably run off AA batteries lol.
                                    MightymanM Offline
                                    MightymanM Offline
                                    @Calum aha yeah but generally people look into it much more than need be. "As long as it fits into the battery compartment" is my motto!
                                    • R Offline
                                      R Offline
                                      reecesloane 2017
                                      So what would be the case now then where and how should I check any help
                                      Would be great
                                        I would be checking continuity between the genny and the battery terminals. It sounds like the engine is generating power enough to sort itself out, it's just a case of sorting out the charging circuit out.
                                        • R Offline
                                          R Offline
                                          reecesloane 2017
                                          It's weird somtimes I think it may be shooting so where it has electric start and also kick start the other day I turned the ignition in and forgot the red on of switch so it was off but when I kicked the bike it was firing envelope a little smoke from the exhaust it wouldn't fully start but was 100% firing then die then I looked at the switch seen it was of turned it on and it started right up could this be an issue or is this normal thanks
