  3. Exhaust
  4. Recommendations on exhaust joining?
14 Posts 8 Posters 5.8k Views 2 Watching
    I used a piece of coolant hose and 2 hose clambs on my dt175 years ago. It held up just fine. I guess you could also use some of that exhaust"cement" that expands and turn solid when exposed to heat (or left to dry) in combination with the coolant hose.
    • MightymanM
      Seems like different rubber hose with exhaust clamps would be the easiest method then. Issue is I can't find rubber hose that thick. 12mm on eBay won't quite cut it..
      • F
        I've got a stock Yamaha joint at home, of you want it you can have it for postage. I'm away till next weekend but I can send it when I'm home
        MightymanM 1 Reply Last reply
        • C
          C
          castrolsniffer
          +1 on the braided hose plus jubilee clips
          I go to the breakers and cut a big piece of any old car rad hoses and it will do about 5 bikes.
          Works every time 👍
            @finnerz89 thanks. I'll keep you in mind, but will try one of the methods mentioned here first 👍
              http://www.ebay.co.uk/itm/222426936515 I got creative with this, it's very rigid.
              Silicone joiners, high temperature is rated at up too 230 degress.
              I have yet to melt anything.
              • MightymanM
                Finally got a roll of this stuff through and it's worked a treat.
                http://www.ebay.co.uk/itm/152444500194
                Haven't been for a full run yet but just revving the bike up it's nice and quiet again and has sealed the exhaust join very well.
                • declanD
                  Just one clip?
                    Just one clip?
                    @declan yeah the ones I ordered were too thin so just one for now.
                    • MightymanM Mightyman
                      @Mightyman ahhh I see
                      • britshgigoloB
                        britshgigoloB
                        britshgigolo
                        i had the same problem so used a 22mm straight copper pipe fitting then silicon hose and has not leaked since hope this helps
