  4. Just about to list on ebay
46 Posts 9 Posters 13.0k Views
  • A andrewj1680
    Only starting the bidding at £1500 calum i expect it will make abit more than that, i think its abit more than tyres ive found the rear swingarm has a bush gone but i have another rear suspension setup that everything is tight on so will fit that. I have started my own little project that i seem to be getting more out of tbh
    @andrewj1680 I mean the frames on these are so solid. My bike got robbed and was completely battered when I got it back. Despite this it still rode fairly straight.
    Suspension is going to effect the handling, obviously.
    The spokes and wheels are straight and true?
    If the spokes are lose then this is going to have adverse effects.
    The engine isn't giving abnormal vibrations?
    • A
      A
      andrewj1680
      I'll see what its like once the rear suspension has been changed, ive changed the rear wheel for another from 1 of my other dts that rode faultless I'll change the front wheel along with the rear suspension and see how it goes, i am thinking about strip and nut and bolt rebuild it again from scratch i think a few corners where cut with it
      • A andrewj1680
        @andrewj1680 How peculiar.
        Are the engine mounts all tightened up properly?
        • A
          A
          andrewj1680
          It was missing the bolt totally under the gear shirter but all mounts were tight and i replaced the bolt but made no difference, ive had the clutch cover off checked the balancer shaft i found a bent oil baffle plate i replaced and the waterpump propeller had been glued so replaced that also all the clutch is balanced right I'm running oit of ideas
          • A andrewj1680
            @andrewj1680 Has the flywheel been modified?
            Some people lighten the flywheel, but if it's not harmonically balanced you'll know.
            Was this the one with the engine not balanceD?
            A 1 Reply Last reply
              Love that colour scheme, hope you get it sorted fella
                A
                A
                andrewj1680
                @calum the flywheel is standard yes its the same bike that i thought the balance shaft was out on but when i stripped it out found it was where someone had glued the water propellor and must of put the clutch cover back on whilst wet the glue has stuck to the oil baffle plate which had then bent it on start up. When running there is no vibration up through the frame now like before however you still know about it if you take it over 60
                • MiniaM
                  MiniaM
                  Minia
                  Absolutely gorgeous. Despite the problems you mention for £1500 it aint bad at all, I'd take it off your hands if I could but my priorities have been shifted due to an accident I've had with the gasgas. Anyway, good luck mate.
                  • A
                    A
                    andrewj1680
                    Thanks for everyones comments turns out whoever rebuilt it had skipped out changing the bottom swingarm bush my spares seem to be coming in handy on this 1
                    • A andrewj1680
                      @andrewj1680 Was this the problem then mate?
                      • A
                        A
                        andrewj1680
                        It was yes i changed the swingarm and it rides like a new bike i have now decided to change the tyres for something more road friendly as you can feel and hear the drag they have on road. Thankful for the comments it pushed me into looking further into it 😊
                        • MightymanM
                          Good to hear you are keeping it then 👍
                            It would have been a shame to list her so cheap when it was a relatively simple fix!
                            I'm glad you sorted it
                            • A andrewj1680
                              @andrewj1680 you putting the tyres on eBay?
                                A
                                A
                                andrewj1680
                                @calum thats it mate I'm gonna put it back totally standard and store it away i think, i have all the standard bits to do it
                                  A
                                  A
                                  andrewj1680
                                  @declan tyres will be going mate yes, open to offers 0_1501002225269_1501002183924565446143.jpg 0_1501002271118_15010022505291098493543.jpg
                                  • A andrewj1680
                                    @andrewj1680 if you throw em on eBay and link me I'll take a look when I can I'm after a set but not got the pennies right now so just do your thing and if I can I'll take them off you
                                    • A andrewj1680
                                      Gotten to the point i hate riding it so going up for sale it looks the part but has to be the worst dt ive ever ridden i just cant put my finger on why, it seems to have a nasty speed wobble at around 60mph and i dont like the idea someone else rebuilt it so time to let it go
                                      scrimsmustang
                                      @andrewj1680 said in Just about to list on ebay:
                                      Im sure ive seen that bike before in Hartlepool im sure its the same one I painted the frame swinging arm forks and tank for the lad who had it. From what I can remember it was a 3PY full power Italian import and it was originally Black. It didnt have that pipe and the engine covers where grey and not silver like they are now when I seen it last all put back together.
                                      • A andrewj1680
                                        @andrewj1680 The bike also looks like it's been lowered, which would also change the bikes handling and ride quality, ergo making the back end feel sluggish.
                                        Have you lowered it dude???
                                        • NottsbikerN
                                          NottsbikerN
                                          Either the linkage or "dog bones" or maybe even a shorter shock.
                                          My TDR is like that and i think the shock might be smaller than a DTR one.
