  3. Welcome New Owners!
  4. New purchase 1990 dt125r
43 Posts 10 Posters 12.7k Views
  • U ukchad
    Yeah, the head gasket is on my radar.
    The oil looked ok when I changed it - so did the coolant, but I will check the consistency tomorrow.
    How big a job is it to do the head gasket for a garage? Ball park cost? I think that may be a stage too far for me to do yet.
    I actually put the power valve back to original position as the exhaust got very hot very quickly (smoking from end after I stopped after a 5 min blast)
    terry.tzT
    terry.tzT
    terry.tz
    @ukchad said in New purchase 1990 dt125r:
    haha I would say leave it open its boring closed I could fall asleep riding if it was not wide open 😁 but I will say I have seen threads where there is a bit of controversy so think it's best you know how your bike runs first so you will tell if it rich or lean through the rev range
    • U ukchad
      Another tool to purchase, but I do love having them.
      Another 1990 welcome! Ignore the sticker bomb and the rear wheel got a puncture in my wheel and chipped paint underneath the sticker bomb lol
      terry.tzT 1 Reply Last reply
        terry.tzT
        terry.tzT
        terry.tz
        @declan coming on that is Declan
          Here's one I prepared earlier !
          U 1 Reply Last reply
          • U
            U
            ukchad
            Is it normal for the exhaust to heat up so much then, when the power valve is fully open?
            Also died a bit when I kicked up into 6th, ran out of power (maybe wasn't high enough revs)
            • O oldman
              U
              U
              ukchad
              @oldman soooo clean
              • U ukchad
                @ukchad coming from 4 stroke this was crazy for me I have full functioning pv) my muffler gets too hot to touch
                • terry.tzT terry.tz
                  @terry-tz hey thank you buddy nice hearing that much appreciated but a lot to go yet 😊
                    terry.tzT
                    terry.tzT
                    terry.tz
                    @declan good to know there's more to come
                      Hello and welcome'
                      Get the servo retro fitted and have a working powervalve. Best of both worlds.
                      Exhaust gets hotter because you spend longer times at higher rpms. Refer back to my previous statement. Get the servo fitted. Less stress on the engine.
                      I would start simple first, check the thermostat, they are probe to failing after zo many years.
                      Head gasket is not the same as a four stroke. No valves no nothing to go wrong.
                      Buy only genuine or athena gasket, skim the head like described in my tutorial, then boom, good to go.
                      Nice bike.
                      declanD U 2 Replies Last reply
                      • MiniaM
                        MiniaM
                        Minia
                        Welcome, looking good 🙂
                          Hello and welcome'
                          Nice bike.
                          @calum what's skimming the head do I know squish and compression etc but does just that on its own yield noticeable results?
                          • U ukchad
                            Hello everyone,
                            Just brought myself a DT125R.
                            Always wanted one since I was knocking around at 15 on my CB125 - finally got the cash to treat myself.
                            Found on EBay
                            UK registered from new, engine and frame numbers match.
                            Bit scruffy, but perfect for me to fiddle around with at the weekends
                            Not sure if I loaded the photo properly!
                            Plenty of tidying to be done on the bike, electrics, decals, plastics, tank etc etc, but looking forward to it and coming here for advice!
                            @ukchad Welcome aboard, looks like you have a decent starting point there. 👍
                              Hello and welcome'
                              Nice bike.
                              U
                              U
                              ukchad
                              @calum so I think I understand.
                              At the moment the power valve either works at low down or higher revs because it is fixed in position?
                              I choose that position by turning 180 degrees either way?
                              By fitting a servo, the power valve is rotated to give me full power depending on revs.
                              Is this correct?
                              My power valve doesn't look like most i see in pictures - no cables or slots for cables in the casing. Just a central bolt, flanked by 2 small outer bolts
                              Can a servo still be retro fitted to this?
                              • NottsbikerN
                                NottsbikerN
                                Yes you are missing the cables, servo, cable housing, cover and pulley.
                                You can get these from any DTR or TDR and they will fit your bike. Not sure on servo motor but i think any DT one can be adapted to fit
                                • U
                                  U
                                  ukchad
                                  Thanks @Nottsbiker
                                  If any one knows, finds or has one that fits please bear me in mind.
                                  I can then start a build thread and you can all watch me mess it up!
                                  • NottsbikerN
                                    NottsbikerN
                                    Think you and i will be after m the same vintage servo motors 😉
                                    Don't out bid me on any lol
                                    • U
                                      U
                                      ukchad
                                      Let me know, and we can make sure!
                                      • A
                                        A
                                        andrewj1680
                                        The powervalve is different you would have to change the whole lot in my opinion its not worth it the servo takes the fun out of it anyway
                                        • A andrewj1680
                                          Any idea what that yellow and black wire does that goes to the powervalve servo it turns using the key still?
