tuningdtryamaha2003wr200
254 Posts 25 Posters 243.6k Views 6 Watching
  • Louis-DT-WRL
    Louis-DT-WRL
    #70
    And here it is fitted
    • Louis-DT-WRL
      Louis-DT-WRL
      #71
      Since aj Sutton are useless at getting parts and took weeks to reply, I cancelled the order and used fowlers of Bristol. And these came a few days later. Now I can fit bearings to my wheels
      • Louis-DT-WRL Louis-DT-WR
        @Louis-James
        MATE Going through the same PAINFUL process. It's been months now and haven't heard anything.
        I think I might just do the same.
          @Louis-James
          Louis-DT-WRL
          Louis-DT-WRL
          @Calum what are you waiting for then? And from aj Sutton?
            @Louis-James Plastics. All except tank plastics.
            Seriosuly I ordered them in January lol.
            • Louis-DT-WRL
              Louis-DT-WRL
              How much is a very good condition dt200r right hand radiator worth to someone who wants a twin rad set up? The metal waterpump pipe in the front of the engine can be easily modified to be used with it also you don't need the 200r left radiator because you can have 2 radiator caps, and you can make buy Y piece hose connector off eBay. I did have it all ready to use on my 200 conversion but overheating was never a problem 🙂
                Louis-DT-WRL
                Louis-DT-WRL
                @Calum fowlers of Bristol are great, they have most of the parts in Stock, their warehouse is massive!!
                  @Louis-James Lol, me and you are like two peas in a pod. I literally have one of those as well!
                  Although I think I paid like £20 for mine.
                    @Louis-James I'd probably pop over to Skellerns but you're right about Fowlers. We have on in Gloucester too!
                      Louis-DT-WRL
                      Louis-DT-WRL
                      @Calum really light weight, I doubt it adds much cooling as it has such a small capacity. Can you fit them on a dtre/x? What's even behind the right hand rad scoop?
                        @Louis-James Relays and rectifier.
                        I'm running DTR Lanza Twin Rads 😄 lol. Yeah does the cooling do anything. Doubt it,
                        • MiniaM
                          MiniaM
                          Minia
                          This looks pretty epic!
                            Louis-DT-WRL
                            Louis-DT-WRL
                            @Calum it's wierd how the lanza was released in 96/97 then the dtre is almost identical when it was released so many years later. Cool setup 😉
                            • MiniaM Minia
                              Louis-DT-WRL
                              Louis-DT-WRL
                              @Minia thanks man, I just saw your thread... Welcome to the forum, I'm liking the originality of your dtr
                              • Louis-DT-WRL
                                Louis-DT-WRL
                                #84
                                I've been waiting so long to fit these wheels and haven't really got time to build them up and fit them 👿 got to go away for nearly a month working and then 2 weeks after I'm in Crete for 2 weeks. I just want to ride my dt 👌alt text
                                • Louis-DT-WRL
                                  Louis-DT-WRL
                                  #85
                                  Some progress, I fitted the front wheel and fitted the bearings, spacer and seals in the rear wheel, I didn't have enough time to fit it though.
                                  • Louis-DT-WRL
                                    Louis-DT-WRL
                                    #86
                                    • Louis-DT-WRL
                                      Louis-DT-WRL
                                      #87
                                      One down, one to go
                                        Is looking sweet!
                                        How did you get on with the car in the end.
                                          Is looking sweet!
                                          Louis-DT-WRL
                                          Louis-DT-WRL
