tuningdtryamaha2003wr200
254 Posts 25 Posters 240.5k Views 6 Watching
  • Louis-DT-WRL Louis-DT-WR
    @Calum really light weight, I doubt it adds much cooling as it has such a small capacity. Can you fit them on a dtre/x? What's even behind the right hand rad scoop?
    @Louis-James Relays and rectifier.
    I'm running DTR Lanza Twin Rads 😄 lol. Yeah does the cooling do anything. Doubt it,
    • MiniaM
      MiniaM
      Minia
      This looks pretty epic!
        Louis-DT-WRL
        Louis-DT-WRL
        @Calum it's wierd how the lanza was released in 96/97 then the dtre is almost identical when it was released so many years later. Cool setup 😉
        • MiniaM Minia
          Louis-DT-WRL
          Louis-DT-WRL
          @Minia thanks man, I just saw your thread... Welcome to the forum, I'm liking the originality of your dtr
          • Louis-DT-WRL
            Louis-DT-WRL
            #84
            I've been waiting so long to fit these wheels and haven't really got time to build them up and fit them 👿 got to go away for nearly a month working and then 2 weeks after I'm in Crete for 2 weeks. I just want to ride my dt 👌alt text
            • Louis-DT-WRL
              Louis-DT-WRL
              #85
              Some progress, I fitted the front wheel and fitted the bearings, spacer and seals in the rear wheel, I didn't have enough time to fit it though.
              • Louis-DT-WRL
                Louis-DT-WRL
                #86
                • Louis-DT-WRL
                  Louis-DT-WRL
                  #87
                  One down, one to go
                    Is looking sweet!
                    How did you get on with the car in the end.
                      Is looking sweet!
                      Louis-DT-WRL
                      Louis-DT-WRL
                      • Louis-DT-WRL
                        Louis-DT-WRL
                        #90
                        Wheels on pointalt text
                        • mad73M
                          mad73M
                          mad73
                          Looking very fine indeed
                          • Louis-DT-WRL
                            Louis-DT-WRL
                            https://youtu.be/cDtMUnvHCIk
                            • mad73M
                              mad73M
                              mad73
                              very nice video m8 a lot of work gone into that bet it goes a lot better now top marks to u
                              • mad73M mad73
                                Louis-DT-WRL
                                Louis-DT-WRL
                                @mad73 yes it does 😉 thanks a lot
                                • Y
                                  Y
                                  yamahalover
                                  Hi. Can you get me contact of the man who makes the engine sump protection and the frameguards? Please. Because I can not find I'm. Pleasantly me know where u get those stainless spokes and nipples. Cause I can't find them either. Thanks.and. Congratulations on that amazing bike
                                  • Y
                                    Y
                                    yamahalover
                                    how can i send a private sms to this man ?
                                    i not know how to use the chat so good
                                    Biker_123B 1 Reply Last reply
                                    • Y yamahalover
                                      Biker_123B
                                      Biker_123B
                                      Biker_123
                                      @yamahalover The guy who makes them can be found on Facebook his Facebook user name is further up this thread but he doesn't make them anymore unfortunately as I've enquired about them myself .
                                      Every problem has a solution
                                        Thanks guys, yes the zeeltronic is amazing. I was the one who helped zeeltronic make a cdi for the dt125r 2003 with my specs, data and wiring with the connector blocks pictures. Really helped set the correct powervalve curve and limits with my wr200 top end and using the dt125r stator plate, also the ignition timing.
                                        aidan1996A
                                        aidan1996A
                                        aidan1996
                                        @Louis-James hi
                                        how much different does the zeeltronic make to you?
                                        does it come with plugs fitted to the cdi?
                                        • aidan1996A aidan1996
                                          @Louis-James hi
                                          Louis-DT-WRL
                                          Louis-DT-WRL
                                          @aidan1996 makes all the difference, especially as I have a wr200 top end. Let's me have more variation from fully close to open on the PV. Also advancing the ignition timing was a big bonus.
                                          Mine was the first one ever for my model of Dt125r which I helped them develop it.
                                          They made mine for free but I had to pay for the hand held programmer.
