tuningdtryamaha2003wr200
254 Posts 25 Posters 240.5k Views 6 Watching
  • Louis-DT-WRL
    Louis-DT-WRL
    #84
    I've been waiting so long to fit these wheels and haven't really got time to build them up and fit them 👿 got to go away for nearly a month working and then 2 weeks after I'm in Crete for 2 weeks. I just want to ride my dt 👌alt text
    • Louis-DT-WRL
      Louis-DT-WRL
      #85
      Some progress, I fitted the front wheel and fitted the bearings, spacer and seals in the rear wheel, I didn't have enough time to fit it though.
      • Louis-DT-WRL
        Louis-DT-WRL
        #86
        • Louis-DT-WRL
          Louis-DT-WRL
          #87
          One down, one to go
            Is looking sweet!
            How did you get on with the car in the end.
              Is looking sweet!
              Louis-DT-WRL
              Louis-DT-WRL
              • Louis-DT-WRL
                Louis-DT-WRL
                #90
                Wheels on pointalt text
                • mad73M
                  mad73M
                  mad73
                  Looking very fine indeed
                  • Louis-DT-WRL
                    Louis-DT-WRL
                    https://youtu.be/cDtMUnvHCIk
                    • mad73M
                      mad73M
                      mad73
                      very nice video m8 a lot of work gone into that bet it goes a lot better now top marks to u
                      • mad73M mad73
                        Louis-DT-WRL
                        Louis-DT-WRL
                        @mad73 yes it does 😉 thanks a lot
                        • Y
                          Y
                          yamahalover
                          Hi. Can you get me contact of the man who makes the engine sump protection and the frameguards? Please. Because I can not find I'm. Pleasantly me know where u get those stainless spokes and nipples. Cause I can't find them either. Thanks.and. Congratulations on that amazing bike
                          • Y
                            Y
                            yamahalover
                            how can i send a private sms to this man ?
                            i not know how to use the chat so good
                            Biker_123B 1 Reply Last reply
                            • Y yamahalover
                              Biker_123B
                              Biker_123B
                              Biker_123
                              @yamahalover The guy who makes them can be found on Facebook his Facebook user name is further up this thread but he doesn't make them anymore unfortunately as I've enquired about them myself .
                              Every problem has a solution
                              • Louis-DT-WRL Louis-DT-WR
                                Thanks guys, yes the zeeltronic is amazing. I was the one who helped zeeltronic make a cdi for the dt125r 2003 with my specs, data and wiring with the connector blocks pictures. Really helped set the correct powervalve curve and limits with my wr200 top end and using the dt125r stator plate, also the ignition timing.
                                aidan1996A
                                aidan1996A
                                aidan1996
                                @Louis-James hi
                                how much different does the zeeltronic make to you?
                                does it come with plugs fitted to the cdi?
                                • aidan1996A aidan1996
                                  @Louis-James hi
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  @aidan1996 makes all the difference, especially as I have a wr200 top end. Let's me have more variation from fully close to open on the PV. Also advancing the ignition timing was a big bonus.
                                  Mine was the first one ever for my model of Dt125r which I helped them develop it.
                                  They made mine for free but I had to pay for the hand held programmer.
                                  • smudge1995S
                                    smudge1995S
                                    smudge1995
                                    That bike is a piece of art!!! Fairplay dude thats one of the best dt's I've seen
                                    • smudge1995S smudge1995
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      @smudge1995 thank you very much
                                        Is looking sweet!
                                        Louis-DT-WRL
                                        Louis-DT-WRL
                                          [[topic:post-is-deleted]]
                                          @Louis-James You need to embed them but.
                                          There is a tutorial on here if you're unsure.
