tuningdtryamaha2003wr200
254 Posts 25 Posters 243.6k Views 6 Watching
    @Louis-James Lol, me and you are like two peas in a pod. I literally have one of those as well!
    Although I think I paid like £20 for mine.
    Louis-DT-WRL
    Louis-DT-WRL
    @Calum really light weight, I doubt it adds much cooling as it has such a small capacity. Can you fit them on a dtre/x? What's even behind the right hand rad scoop?
    • Louis-DT-WRL Louis-DT-WR
      @Louis-James Relays and rectifier.
      I'm running DTR Lanza Twin Rads 😄 lol. Yeah does the cooling do anything. Doubt it,
      • MiniaM
        MiniaM
        Minia
        This looks pretty epic!
          Louis-DT-WRL
          Louis-DT-WRL
          @Calum it's wierd how the lanza was released in 96/97 then the dtre is almost identical when it was released so many years later. Cool setup 😉
          • MiniaM Minia
            Louis-DT-WRL
            Louis-DT-WRL
            @Minia thanks man, I just saw your thread... Welcome to the forum, I'm liking the originality of your dtr
            • Louis-DT-WRL
              Louis-DT-WRL
              #84
              I've been waiting so long to fit these wheels and haven't really got time to build them up and fit them 👿 got to go away for nearly a month working and then 2 weeks after I'm in Crete for 2 weeks. I just want to ride my dt 👌alt text
              • Louis-DT-WRL
                Louis-DT-WRL
                #85
                Some progress, I fitted the front wheel and fitted the bearings, spacer and seals in the rear wheel, I didn't have enough time to fit it though.
                • Louis-DT-WRL
                  Louis-DT-WRL
                  #86
                  • Louis-DT-WRL
                    Louis-DT-WRL
                    #87
                    One down, one to go
                      Is looking sweet!
                      How did you get on with the car in the end.
                        Is looking sweet!
                        Louis-DT-WRL
                        Louis-DT-WRL
                        • Louis-DT-WRL
                          Louis-DT-WRL
                          #90
                          Wheels on pointalt text
                          • mad73M
                            mad73M
                            mad73
                            Looking very fine indeed
                            • Louis-DT-WRL
                              Louis-DT-WRL
                              https://youtu.be/cDtMUnvHCIk
                              • mad73M
                                mad73M
                                mad73
                                very nice video m8 a lot of work gone into that bet it goes a lot better now top marks to u
                                • mad73M mad73
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  @mad73 yes it does 😉 thanks a lot
                                  • Y
                                    Y
                                    yamahalover
                                    Hi. Can you get me contact of the man who makes the engine sump protection and the frameguards? Please. Because I can not find I'm. Pleasantly me know where u get those stainless spokes and nipples. Cause I can't find them either. Thanks.and. Congratulations on that amazing bike
                                    • Y
                                      Y
                                      yamahalover
                                      how can i send a private sms to this man ?
                                      i not know how to use the chat so good
                                      Biker_123B 1 Reply Last reply
                                      • Y yamahalover
                                        Biker_123B
                                        Biker_123B
                                        Biker_123
                                        @yamahalover The guy who makes them can be found on Facebook his Facebook user name is further up this thread but he doesn't make them anymore unfortunately as I've enquired about them myself .
                                        Every problem has a solution
                                          Thanks guys, yes the zeeltronic is amazing. I was the one who helped zeeltronic make a cdi for the dt125r 2003 with my specs, data and wiring with the connector blocks pictures. Really helped set the correct powervalve curve and limits with my wr200 top end and using the dt125r stator plate, also the ignition timing.
                                          aidan1996A
                                          aidan1996A
                                          aidan1996
                                          @Louis-James hi
                                          how much different does the zeeltronic make to you?
                                          does it come with plugs fitted to the cdi?
