  3. TDR
  4. Belgarda Yamaha TDR125 3SH
37 Posts 6 Posters 19.8k Views
  • NottsbikerN Offline
    NottsbikerN Offline
    Aaaaaaaaaaaaaaaaaarrrrrrrrrrrrrgggggggggghhhhhhhhhh
      NottsbikerN Offline
      Mines black but looks like it's been used for target practice by some hillbillies so mines probably getting junked.
      Looking at ebay europe at mo so will probably collect a full set over the winter from various different countries as just as cost effective as buying random panels here and having painted.
      Out in the sunshine today sanding the rust off my frame before treating it then storing until I can afford the rebuild. Got my airbox apart as well for cleaning and randomly someone's cut a bloody hole in the battery tray - wtf for i don't know.
      • NottsbikerN Nottsbiker
        scrimsmustang
        @nottsbiker
        The K reg TDR125R belgarda is now a White n Pink DTR after a bit of modding to the frame it was a 3XE2 model, the wheels brakes forks and swinging arm are now on a 2001 DTR Hurricane Hanna replica
        This is the type we decked, bike was identical only wheels fork and swinging arm were painted black
        • S scrimsmustang
          @nottsbiker
          scrimsmustang
          @scrimsmustang
          Ive done the conversion before on this 2002 DTR back in 2005 its just a bolt on job, this time ive removed all the unnecessary brackets from the forks.
            NottsbikerN Offline
            If I wanted the 3 spoke alloys I'd fit the same as in your pictures but mine are the first model spoked wheels and I quite like them. Unfortunately Yamaha back in the late 80's went with an 18 inch front rim which limits tyre choice so I'm probably going to have another rim laced onto my front hub as my wheels are ready to be done now. The standard rims are aluminium so it would be a good match to put a rear on the front hub.
            The swingarm on the later ones also suits the alloy wheels nicely but I can't make out if its steel or ally?
              @nottsbiker I believe it's steel.
                NottsbikerN Offline
                Shame its a nicer shape than stock but when / if I change something I like to upgrade a possibly save some weight.
                S 2 Replies Last reply
                  scrimsmustang
                  @nottsbiker
                  This swinging arm the one I have now is steel but the one on the Blue bike im sure was alloy ? Cant remember to be honest was years ago now but it came from the same type of bike..
                    scrimsmustang
                    @nottsbiker said in Belgarda Yamaha TDR125 3SH:
                    I used the TDR swinging arm as it made the life easy for the wheels, its designed for the alloy wheels and rear brake,the chain tensioners etc and bolts straight to the DT frame.
                    • S scrimsmustang
                      @nottsbiker
                      @scrimsmustang See I remember asking you way back when, pretty sure you said it was steel at the time
                        scrimsmustang
                        @calum said in Belgarda Yamaha TDR125 3SH:
                        Probably was steel Cal, the one I have now is and its off the same type of bike.
                          NottsbikerN Offline
                          Ok thanks for clearing it up
                          • T Offline
                            T Offline
                            TDRnoob
                            Hi. I am looking for new fork seals and steering bearings for my 1990 belgarda. Do you know if it is the same as DT?
                            Links for ebay
                            http://www.ebay.co.uk/itm/Fork-Seals-Dust-Seals-YAMAHA-DT125R-1988-04-/321368473581?hash=item4ad30dbfed:g:FSEAAOxyRhBS-ZeM
                            http://www.ebay.co.uk/itm/Yamaha-DT125-R-91-03-Steering-Head-Stem-Bearings/231863950530?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
                            • T TDRnoob
                              Links for ebay
                              @tdrnoob Biggest clue is going to be in the part numbers.
                              However, if this were me, I'd grab my vernier calipers and simply measure it.
                              Then head over to simplybearings.co.uk and just buy Koyo bearings as a replacement. Cheap and easy job.
                              T 1 Reply Last reply
                                T Offline
                                T Offline
                                TDRnoob
                                @calum Good idea. Thanks
                                  NottsbikerN Offline
                                  Steering bearings probably yes. Fork seals no idea as DTR are possibly Kayaba and TDR are Paoli so might be different even though the stancions are the same diameter.
                                    scrimsmustang
                                    Yes they are different to a DTR
                                      NottsbikerN Offline
                                      I'm tempted with YZ/WR forks with a supermoto calliper spacer to run the stock Brembo disc maybe with a matching Brembo goldline calliper as the TDR disc is exactly the same as my 900 Monster
                                        NottsbikerN Offline
                                        Meant to add that my original calliper was glued on with one of the mounts, so god only knows how it 'passed' its last MOT.
                                        This will teach me not to bid on ebay late at night with the old "I'll never win that...."
                                        3
                                          @nottsbiker better to own a scrap bike than no bike at all lol and my bike came with the front calliper cable tied to the forks lol
