  3. TDR
  4. Belgarda Yamaha TDR125 3SH
37 Posts 6 Posters 20.1k Views
  • S scrimsmustang
    @nottsbiker
    The K reg TDR125R belgarda is now a White n Pink DTR after a bit of modding to the frame it was a 3XE2 model, the wheels brakes forks and swinging arm are now on a 2001 DTR Hurricane Hanna replica
    This is the type we decked, bike was identical only wheels fork and swinging arm were painted black
    scrimsmustang
    @scrimsmustang
    Ive done the conversion before on this 2002 DTR back in 2005 its just a bolt on job, this time ive removed all the unnecessary brackets from the forks.
    • NottsbikerN
      NottsbikerN
      If I wanted the 3 spoke alloys I'd fit the same as in your pictures but mine are the first model spoked wheels and I quite like them. Unfortunately Yamaha back in the late 80's went with an 18 inch front rim which limits tyre choice so I'm probably going to have another rim laced onto my front hub as my wheels are ready to be done now. The standard rims are aluminium so it would be a good match to put a rear on the front hub.
      The swingarm on the later ones also suits the alloy wheels nicely but I can't make out if its steel or ally?
      • NottsbikerN Nottsbiker
        @nottsbiker I believe it's steel.
        • NottsbikerN
          NottsbikerN
          Shame its a nicer shape than stock but when / if I change something I like to upgrade a possibly save some weight.
          S 2 Replies Last reply
            scrimsmustang
            @nottsbiker
            This swinging arm the one I have now is steel but the one on the Blue bike im sure was alloy ? Cant remember to be honest was years ago now but it came from the same type of bike..
              scrimsmustang
              @nottsbiker said in Belgarda Yamaha TDR125 3SH:
              I used the TDR swinging arm as it made the life easy for the wheels, its designed for the alloy wheels and rear brake,the chain tensioners etc and bolts straight to the DT frame.
              • S scrimsmustang
                @nottsbiker
                @scrimsmustang See I remember asking you way back when, pretty sure you said it was steel at the time
                  scrimsmustang
                  @calum said in Belgarda Yamaha TDR125 3SH:
                  Probably was steel Cal, the one I have now is and its off the same type of bike.
                  • NottsbikerN
                    NottsbikerN
                    Ok thanks for clearing it up
                    • T
                      T
                      TDRnoob
                      Hi. I am looking for new fork seals and steering bearings for my 1990 belgarda. Do you know if it is the same as DT?
                      Links for ebay
                      http://www.ebay.co.uk/itm/Fork-Seals-Dust-Seals-YAMAHA-DT125R-1988-04-/321368473581?hash=item4ad30dbfed:g:FSEAAOxyRhBS-ZeM
                      http://www.ebay.co.uk/itm/Yamaha-DT125-R-91-03-Steering-Head-Stem-Bearings/231863950530?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
                      • T TDRnoob
                        Links for ebay
                        @tdrnoob Biggest clue is going to be in the part numbers.
                        However, if this were me, I'd grab my vernier calipers and simply measure it.
                        Then head over to simplybearings.co.uk and just buy Koyo bearings as a replacement. Cheap and easy job.
                        T 1 Reply Last reply
                          T
                          T
                          TDRnoob
                          @calum Good idea. Thanks
                          • NottsbikerN
                            NottsbikerN
                            Steering bearings probably yes. Fork seals no idea as DTR are possibly Kayaba and TDR are Paoli so might be different even though the stancions are the same diameter.
                              scrimsmustang
                              Yes they are different to a DTR
                              • NottsbikerN
                                NottsbikerN
                                I'm tempted with YZ/WR forks with a supermoto calliper spacer to run the stock Brembo disc maybe with a matching Brembo goldline calliper as the TDR disc is exactly the same as my 900 Monster
                                • NottsbikerN
                                  NottsbikerN
                                  Meant to add that my original calliper was glued on with one of the mounts, so god only knows how it 'passed' its last MOT.
                                  This will teach me not to bid on ebay late at night with the old "I'll never win that...."
                                  3
                                    @nottsbiker better to own a scrap bike than no bike at all lol and my bike came with the front calliper cable tied to the forks lol
                                    • NottsbikerN
                                      NottsbikerN
                                      Think yours was safer...
                                      Had forgotten what buying a total nail was like. This bike is reminding me everytime I go near it.
                                        @nottsbiker well mine was worse trust me but I managed to scrape by without going into crippling debt
                                        • NottsbikerN
                                          NottsbikerN
                                          This is going to be an over winter project along with my Monster as I've got to choose between spending my spare (lol) cash on my garage or building the bikes up. Whilst the bikes are the most interesting the garage project is the one which will enable the bikes to be built quicker, later.
