  4. Swing arm movement
Swing arm movement
17 Posts 5 Posters 2.9k Views
  • K Offline
    K Offline
    kylescave
    So i have been building two DT 125r's for a while now. However they both seem to have up and down movement in the swing arm. I'm struggling to find a bearing kit that i'm certain would fit.
    Any help or advice would be appreciated.
    when on a stand the swing arm will move about 3-5 mm up and down. I'm sure this would fail an MOT so want to get it sorted ASAP so i can sell it.
    S D 2 Replies Last reply
    • K kylescave
      @kylescave
      You mean at the frame/swingarm bolt?! That sounds beyond wear. I’d check the bolt is the proper size...
      K 1 Reply Last reply
      • K kylescave
        DTR+NSR
        @kylescave there's a needle bearing and sleeve, where the swingarm pivots on the frame bolt. Pretty sure its a common size bearing, possibly 22x28x20mm but don't hold me to that.
          @dtr-nsr Bearing sizes should be on this forum somewhere.
            @kylescave
            K Offline
            K Offline
            kylescave
            @SpookDog No i do not think it is the swingarm bolt. From what i can see its moving from the rear shock linkage. I'm not sure of the name. Wishbone? Dogbone? So i believe its the bearings or sleeves in that.
            But both my Dt's have this issue otherwise i would have swapped the part for now.
            • D DTR+NSR
              K Offline
              K Offline
              kylescave
              @DTR-NSR I've changed the sleeve bearing that the swing arm bolt goes through if that's what you mean. But i think the movement is coming from the rear shock linkage. where it bolts onto the swing arm? Or is that what you meant.
              I was going to replace the bearings/sleeve in that link however im struggling to find a kit.
              • K kylescave
                @kylescave Should still be able to get these parts from Yamaha
                90387-164U8 - Part number for the collars
                I'd grab genuine collars then get the bearings from SimplyBearings.co.uk
                  K Offline
                  K Offline
                  kylescave
                  @Calum Okay sounds good, any chance you know the bearing size or can direct me to where i can find them? Many thanks.
                  • K kylescave
                    @kylescave The bearings will have markings on them that you can use for reference. Simplybearings.co.uk will have them, that's where I got them from.
                    https://www.ebay.co.uk/itm/112551533577
                    But someone is selling them on eBay for £20
                      K Offline
                      K Offline
                      kylescave
                      @Calum Aren't those the swing arm bearings though? They are the ones I've replaced. Or is it possible that the linkage uses the same bearing.
                      • K kylescave
                        @kylescave No sorry, they were the swinging arm bearings.
                        I vaguely remember doing them on mine. But I can't recall what the sizes were. Just press them out and get the part number from them
                          K Offline
                          K Offline
                          kylescave
                          @Calum Alright no worries, I'll give that a go. Thanks for the advice.
                          • K kylescave
                            @kylescave
                            Do a search for :
                            ‘Yamaha DT125R rear suspension linkage repair kit’
                            It’s not cheap (@ £110) but once done and properly maintained it should last forever. Nobody greases up the nipples on these! That’s why they fail...
                              @spookdog that and by this point they are like a million years old
                              • NottsbikerN Offline
                                NottsbikerN Offline
                                I've collected all the parts to do the swingarm on my TDR (basically a DTR) from Yamaha / Wemoto and they were horrendously expensive. Bet its cost something daft like two hundred quid or even more for the 125 bits.
                                Strange then that All Balls make a kit for my DT200WR that includes everything across a couple of kits for around a hundred quid!
                                • NottsbikerN Nottsbiker
                                  @Nottsbiker
                                  Most stolen bike in the UK tax!...
                                  If you checked the sizes I bet most bits are the same. The 200 does have an ally swing arm though, no?...
                                    @Nottsbiker
                                    NottsbikerN Offline
                                    NottsbikerN Offline
                                    @SpookDog yes the 200wr has an aluminum swingarm but so does my 125r (got a dt200r one) and I bet you are correct that loads of bits are the same.
                                    Oddly though the the 200 is narrower than the 125 with the linkage mount a different distance from the pivot so would not be a direct swap either
