  3. DTX
  4. Dtx Project Codename Moneypit
77 Posts 13 Posters 34.8k Views 2 Watching
    Anything is possible. No it's not a direct fit, but if it were then every joey would have done it.
    The only reason I didn't do it, was because I spent many many nights lining up my supermoto wheels with my current setup, changing the arm, whilst trivial, would have undone all that work.
    @Calum Big respect to all Joey's!!! LOL 😉
      To do it properly you are going to need to realign the whole geometry of the bike.
      With the new swingarm you are going to need the YZ brake carrier. Which will need modifiying to either accept your brake, or use the YZ brakes.
      Either way the swingarm needs altering to fit between the frame and the engine.
      This will cause the sprocket to be out of alignment with the rear sprocket, which is going to to cause undue stress to the gearbox bearings. This will need correcting by either shimming or machining.
      You are then going to find the front and rear wheels are no longer in line. So this will need altering to ensure that the front and rear wheels are inline, and the front and rear sprockets are inline.
      If you don't then you will find the bike will have a tendency to crab or to cause excessive damage to the gearbox.
      This is why my front wheel is off centre from the forks. This was done to ensure the front and rear wheels line up perfectly, whilst maintaining the correct geometry for the front and rear sprockets.
      I'm all for the swingarm conversion, but it sounds like you haven't thought this through enough?
      If you're going to do, do it right. Is all I'm going to say.
      It's just a case of measuring once, twice three times to be sure. This is the reason why I didn't use the alloy swingarm, AFTER I had already done all of this measuring.
      I should have done it all at one time and saved myself the effort of measuring twice.
      If any of that is unclear I am happy to go into more detail.
      ZrakoZ 1 Reply Last reply
        ZrakoZ
        ZrakoZ
        Zrako
        @Calum yeah to be honest Im thought its lot easier than it really is and I havent the yz swingarm in the hand to get the measurements.
        Definitely I have only 2 ways of doing this: properly or stock swingarm.
        1979 Jawa Mustang 50
        2003 Gilera DNA 125 R.I.P
        2015 Keeway TX 125 SM
        2006 Yamaha DT 125 X
        • G
          G
          gareth_iowc
          I'm keeping the stock arm and swapping the wheel hubs over just to keep the project going ATM. I did like the idea of the yz wheel adjustment on the rear as it looks smarter than the dt 1
          DT125R 2000
          DRZ400 2006
          Golf Mk3 20v Turbo 1996
          • G gareth_iowc
            ZrakoZ
            ZrakoZ
            Zrako
            @gareth_iowc are you on supermoto project as well?
            • DartyD
              DartyD
              #26
              Well I have seen quite a few DTRs with YZ250/WR400 swingarms. Doable.
              Custom linkage brackets, fabricated an welded...
              Complete YZ/WR rear end,, new chain/ possibly only a 520.
              A earlier style YZ/WR shock will only just clear the exhaust, and will need a custom spacer just to fit it into frame shock tower!
              This is a proper fabrication job.
              This was the very reason a WR200 swingarm was the ONLY choice for me.
              • G
                G
                gareth_iowc
                @zrako I'm sticking with off road but I want to use the 19" rear
                DT125R 2000
                DRZ400 2006
                  Yeah if you wanted to do minimal fabrication then buy a YZ rear end and shock, this would minimise a lot of stuff.
                  If I had a garage I would happily make these sorts of bits for people. But I am so tight for storage at the moment it simply is not possible!
                  • ZrakoZ
                    ZrakoZ
                    Zrako
                    Guys , desperately searching internet for the complete set of swingarm bearings , pins , thrust washers , bearings . Heeelp please ☺
                    • ZrakoZ Zrako
                      @Zrako just measure them and go to simplybearings
                        ZrakoZ
                        ZrakoZ
                        Zrako
                        @Calum will do mate . Im thought that Im found one but its for 78-81 model.
                          As said I got all mine off simply bearings no problem. Saved loads of money as well!
                          • ZrakoZ
                            ZrakoZ
                            Zrako
                            Small update . Engine rebuilt and frame finally came back from powdercoating. Not sure if I love the change but have to deal with it now 😂 0_1491671835721_20170407_180013.jpg
                            3
                            • ZrakoZ Zrako
                              @Zrako Yes mate that is looking lovely!
                              • ZrakoZ Zrako
                                @Zrako If it's not as you originally envisaged, most of it will be hidden anyways, so it's all good really!!! 😉
                                • G
                                  G
                                  gareth_iowc
                                  Same frame colour as me. I like it 🙂
                                  DT125R 2000
                                  DRZ400 2006
                                  • ZrakoZ
                                    ZrakoZ
                                    Zrako
                                    Shame I have to wait till monday to build it up as I work all weekend now. Still no bearings for swingarm as I need all seals and the needle bearing shafts...😓
                                    • Louis-DT-WRL
                                      Louis-DT-WRL
                                      Louis-DT-WR
                                      The wr200 one if I remember rightly is a direct fit with the correct links.
                                      Dt200r is also aluminium but not as chunky
                                      • ZrakoZ
                                        ZrakoZ
                                        Zrako
                                        Well , building it up slowly and ended up at coolant section so far. Just want to be 100% sure - the hose from radiator that going to expansion tank joins on bottom of tank and the top one is breather hose that ends up under engine? Forgot what way it was before... 😶
                                        • ZrakoZ Zrako
                                          @Zrako If you think about it, it's obvious.
                                          If it fed in through the top it would immediately drip out.
                                          So you feed it in through the bottom, if it feeds in too much the overflow at the top will allow it drip out, usually an indication when the head gasket has failed.
                                          So yes, from the radiator to the bottom of the expansion bottle.
