  3. Welcome New Owners!
  4. Dtr125 powervalve help
17 Posts 7 Posters 8.2k Views 1 Watching
  • ijohney123I Offline
    ijohney123I Offline
    ijohney123
    Having trouble wireing powervalve on my dtr125 engine fitted into kx125 frame engine only kickstart servo is 5 wire servo cdi has 3 spare wires ???
      Someone will correct me, the five wire servos, didn't I read they ran off a separate ECU? Or did I dream that.
        ijohney123I Offline
        ijohney123
        Have no idea first 2 stroke ive had had alil troble getn engine to fit.but all in n running jst dnt sound good seems to lack revs power not rode yet waitn on new sprocket n chain
        MightymanM 1 Reply Last reply
        • D Offline
          dan28
          Are you spare wires
          One black yel bullet
          An other 2 one brown one black both live in same connector ?
          If so you need a 3 wire servo
          5 wire servos also need a contrôlér but 3 don't 🙂
          • ijohney123I ijohney123
            MightymanM Offline
            MightymanM Offline
            @ijohney123 I'de like to see some pictures if you have any, would be interesting seeing how you've mounted the engine.
              ijohney123I Offline
              ijohney123
              No spare wires from cdi are blue n light blue in sam connector n a yellow black on its own tryn upload pic avn trouble have a spare 4 wire plug coming from engine
                ijohney123I Offline
                ijohney123
                Tryed 2 open srrvo with a 12v battery and cant seem to get it to do anything
                  ijohney123I Offline
                  ijohney123
                  0_1492859553104_IMG_3925.JPG spare wires cdi
                    ijohney123I Offline
                    ijohney123
                    0_1492859608258_IMG_3923.JPG servo wires
                    0_1492869568476_IMG_3924.JPG spare wire from engine
                    0_1492869635119_IMG_3933.JPG wire from cdi to coil
                    • ZrakoZ Offline
                      ZrakoZ Offline
                      Zrako
                      Im not sure if this helps you but here is the wiring diagrams from haynes manual 0_1492871263096_20170422_152547.jpg
                      1979 Jawa Mustang 50
                      2003 Gilera DNA 125 R.I.P
                      2015 Keeway TX 125 SM
                      2006 Yamaha DT 125 X
                        ijohney123I Offline
                        ijohney123
                        I need a control unit for may servo
                          ijohney123I Offline
                          ijohney123
                          0_1492935630033_IMG_3936.PNG look like tht trying to find 1 anybody know any1 stripping 1 ?
                            Can you not just get the CDI that will do both the ignition and servo.
                            I run a Zeeltronic on mine, which is hands down the best bang for buck in terms of performance. Gives you complete control over the YPVS operation.
                            ijohney123I 1 Reply Last reply
                            • DartyD Offline
                              DartyD Offline
                              wrote on last edited by Darty
                              If you have a 5 wire loom, then YPVS is controlled via the single CDI unit, you should be looking for a 3RM -?
                              Seperate Servo controllers were one year only on the DT125R back in 1988. 3 wire looms,
                                ijohney123I Offline
                                ijohney123I Offline
                                ijohney123
                                @Calum how much u unit
                                • DartyD Darty
                                  ijohney123I Offline
                                  ijohney123I Offline
                                  ijohney123
                                  @Darty u hav 3gm cdi is this all i need
                                  • V Offline
                                    V Offline
                                    vtrn_raptor
                                    Theirs a few on eBay
