  3. Carburetor
  4. Carb warming pipes
Carb warming pipes
20 Posts 9 Posters 7.3k Views
  • A Offline
    A Offline
    andrewj1680
    Just wondering what you guys think I looking at my options to run a bigger carb do I need to run the carb warmup pipes will I lose anything by looping them together or blanking them? Thanks in advance
    • MightymanM Offline
      MightymanM Offline
      I ran my bike for the past year+ of riding without the carb warming pipes and only hooked them back up recently. I wasn't affected by carb icing at all. It's the only bike I've ever seen them on tbh.
      A 1 Reply Last reply
      • MightymanM Mightyman
        A Offline
        A Offline
        andrewj1680
        @Mightyman thanks mate I only run mine during the warmer weather so guessing I will get away with it if that's the case, just don't want to cook the motor
        MightymanM 1 Reply Last reply
        • A andrewj1680
          MightymanM Offline
          MightymanM Offline
          @andrewj1680 it should have no noticeable affect on the engine at all. Its only there to prevent the carb icing up and getting stuck open in extremely cold weather.
            I haven't ran them.for years.
            • A Offline
              A Offline
              andrewj1680
              Ideal appreciate the response, opens my options up about what I can put on there I have a 35mm pwk air striker carb I'm wondering if that maybe too much
              • ZrakoZ Offline
                ZrakoZ Offline
                Zrako
                Is that a banshee carb ?
                1979 Jawa Mustang 50
                2003 Gilera DNA 125 R.I.P
                2015 Keeway TX 125 SM
                2006 Yamaha DT 125 X
                • ZrakoZ Zrako
                  A Offline
                  A Offline
                  andrewj1680
                  @Zrako I think so yes, it was also on my cr500 originally someone had tamed it down it now has a 39mm
                  • ZrakoZ Offline
                    ZrakoZ Offline
                    Zrako
                    Haha Im not surprised , cr500 is a beast . Any pic mate ? 😊
                    • ZrakoZ Zrako
                      A Offline
                      A Offline
                      andrewj1680
                      There you go mate its in a cr450f frame
                      ZrakoZ N 2 Replies Last reply
                      4
                      • A andrewj1680
                        ZrakoZ Offline
                        ZrakoZ Offline
                        Zrako
                        @andrewj1680 looks awesome mate 😍
                        • A andrewj1680
                          @andrewj1680 Sweet ride!!! πŸ‘
                            I mean that's the dream right there...
                            • terry.tzT Offline
                              terry.tzT Offline
                              terry.tz
                              look fun to much fun πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                              • Louis-DT-WRL Offline
                                Louis-DT-WR
                                Road register it πŸ™‚
                                • Louis-DT-WRL Louis-DT-WR
                                  MightymanM Offline
                                  MightymanM Offline
                                  @Louis-James he mentioned in the other thread it's a road registered bike but no MOT at the moment.
                                  • D Offline
                                    dan28
                                    If you don't use the pipes do they need to be blocked off
                                    Or can they be removed from the carb altogether by warming the carb an removing the pipes so it looks neat
                                    What about the head an thermostat housing can these be blocked off
                                    Does any one have a pic to show how they have done it
                                    • D dan28
                                      @dan28 Leave the carb alone. But the head will need to be blocked off, or lines looped, else you'll have coolant coming out of the head.
                                        @calum you can’t block it can you isn’t it a transfer for coolant?
                                          @declan Not the hoses he's referring to.
