  4. Zeeltronic
Zeeltronic
11 Posts 5 Posters 2.7k Views 1 Watching
  • A
    A
    andrewj1680
    So I'm fitting my 3xp motor into my dtr zeeltronic doesn't do a cdi to run it so wondering if I will just get away with swapping all the electrics over and buying a later servo model loom as my current setup doesn't have the servo unit
      Don't they. What was @Louis-James using?
      A 1 Reply Last reply
        A
        A
        andrewj1680
        @Calum I'm guessing he's using the dt setup
        • A andrewj1680
          Louis-DT-WRL
          Louis-DT-WRL
          Louis-DT-WR
          @andrewj1680 it's different because my looming, PV servo and stator is the standard Dt125r, but with a wr200 top end and crank. They probably could make one, as mine was the first for my year of Dt125r
          • A
            A
            andrewj1680
            The thing is there is a market for the dt unit where as the wr isn't as common so at a guess no benefit to them making a single unit
            • A andrewj1680
              @andrewj1680 Is there really much gain from a Zeeltronic on the wr, since this was a competition motor.
              DartyD 1 Reply Last reply
              • A
                A
                andrewj1680
                I don't know to be fair the bike seemed to go well but zeeltronic could possibly take it a step further
                  DartyD
                  DartyD
                  wrote on last edited by Darty
                  @Calum Probably a fair bit, still a very sedate design
                  @andrewj1680 You could probably get a good enough tune using the DT zeel tho,
                  The WR could do with a little more ignition advance,
                  • A andrewj1680
                    @andrewj1680 Are they not able to make you a custom map at all???
                    • DartyD Darty
                      A
                      A
                      andrewj1680
                      @Darty I was thinking swap all the electrics for the dt and run a late loom as I can keep the battery too then otherwise it means running the wr200 loom with the power cap
                      • A andrewj1680
                        DartyD
                        DartyD
                        @andrewj1680 Not a bad idea, should work fine
