  4. 1988 rebuild update
1988 rebuild update
218 Posts 16 Posters 131.2k Views 2 Watching
  • O Offline
    O Offline
    It is downstream of the carb, air drawn in rather than through carb hence starting difficulties, just as well found now, could have been much worse if I was caning it around, will try and post a pic hortly
    • O Offline
      O Offline
      • NottsbikerN Nottsbiker
        Only the ones with the additional intake silencer attachment will be left before long 😞
        @nottsbiker It's not a silencer. It's Yamaha Energy Intake System and is used to as a resonance boost bottle.
        I've explained it before, but probably poorly. Definitely research it.
        • NottsbikerN Offline
          NottsbikerN Offline
          Jesus! How did your guide dog get that carb in there and miss that massive split 😉
            NottsbikerN Offline
            NottsbikerN Offline
            @calum said in 1988 rebuild update:
            I know what the YEIS does but I'm unsure if the second 'bottle' is a boost bottle and always assumed it was a modification by Yamaha to the older engine to either quieten it down more or improve emissions.
              @nottsbiker As @AndyYam used to say, the competition WR had those same bottles. They wouldn't restrict a competition bike.
              NottsbikerN DartyD 2 Replies Last reply
              • O Offline
                O Offline
                Split was not there when reassembled, ran fine at the time, been a few weeks since then waiting for wheels to be done, just old rubber I guess, could have gone anytime
                  NottsbikerN Offline
                  NottsbikerN Offline
                  Just had to Google that to check and you are correct 😉
                  • O Offline
                    O Offline
                    Had a look for the tdr exploded diagrams on csml, intake looks the same but different part nos, bad news is that one is €65 exc postage
                    • O Offline
                      O Offline
                      Still can't see a second bottle though. Only the normal bottle?
                        NottsbikerN Offline
                        Yes I thought that might be the case due to having the dellorto rather than the mikuni carb.
                        If i could find a 200R engine I'd use the associated carb which I reckon is the same 28mm mikuni as the DTR
                          DartyD Offline
                          DartyD Offline
                          @calum Not 100%, Yamaha restriced the intake volume on the WR200 for ridabilty,
                          It was never intended for competition, it's a trail bike. Hence their effort to smooth out intake pulses at low RPM with YIES.
                          • O oldman
                            @oldman I had that exact same split I had to glue mine though
                            • O Offline
                              O Offline
                              Ordered the new one but will repair old one when I get it off, what glue did you use and how is it holding up?
                                NottsbikerN Offline
                                Mine was smothered in silicone. Doubt you'll get a glue that remains flexible enough, although a contact adhesive like carpet glue might work.
                                • O oldman
                                  @oldman just used some cheap super glue from the local paper shop its friendly to rubber wood etc and as far as I know it worked a treat
                                  • F Offline
                                    F Offline
                                    I'd try super glue as well
                                      Not how I'd do it. Replace the item, it's cheap enough new from Yamaha.
                                      Ultimately if that part starts to weep, you're going to run your bike lean, and before you know it, you'll burn a hole through your piston, as well as your wallet.
                                      And people wonder why DT's can be in right dog states.
                                        @calum well obviously new parts are adviseable
                                        • O Offline
                                          O Offline
                                          No notification of delivery yet, maybe tomorrow, would only use old one as emergency spare if I was satisfied it was serviceable. Lasted a fair few years so new one will last a while, will probably replace the 89 as well when I get that far, peace of mind and no disappointment
                                          A 1 Reply Last reply
