  4. After some expert help!
32 Posts 8 Posters 7.1k Views
  • ZrakoZ
    ZrakoZ
    Zrako
    Try to take spark plug off and bump it a few meters . Put spark plug back and should be ok. Happened to me few times .
    1979 Jawa Mustang 50
    2003 Gilera DNA 125 R.I.P
    2015 Keeway TX 125 SM
    2006 Yamaha DT 125 X
    • ricky0115R
      ricky0115R
      ricky0115
      How do you mean? just run with it in gear?
      • ricky0115R ricky0115
        @ricky0115 No damage, it can cause bore wash but I doubt there will be any problems here.
        Choke on to start, then once the revs die down, take the choke off and that's it.
        • ricky0115R
          ricky0115R
          ricky0115
          Thanks I will give it a go.
          Any idea on the carb overflow? Tried tapping the float end in case it was jammed but no luck. Thinking about taking it to a garage and having all the seals replaced. Noticed a threaded bolt on the reed block, would this cause an air leak?
          • ricky0115R
            ricky0115R
            ricky0115
            Okay so I just tried kicking it up and on the third kick I heard a puff of air like a blow off valve letting out pressure but I'm unsure where it came from it sounded like it was somewhere near the carb or air filter
              @ricky0115 Probably tried to fire up but failed.
              You haven't blown a hole through the piston have you? It does start right?
              • ricky0115R
                ricky0115R
                ricky0115
                @Calum It will only start from bumping it, I'm going to take it to the garage on thursday so I will update with the issue.
                • MightymanM
                  A couple of my bikes used to occasionally make that sound when I was kicking them. I'm sure it only happens on an engine that isn't perfectly set up / running little bit lean or little bit rich? Either way the bikes ran okay.
                  • MightymanM Mightyman
                    @mightyman I've only known 4 strokes to make that sound
                    ricky0115R 1 Reply Last reply
                    • A
                      A
                      andrewj1680
                      I'd say piston rings at a guess maybe just a cracked ring would cause issues
                      • A andrewj1680
                        ricky0115R
                        ricky0115R
                        ricky0115
                        @andrewj1680 thanks
                          ricky0115R
                          ricky0115R
                          ricky0115
                          @declan I think it's drawing in way too much air, everything is standard air intake wise. How can I find the piston size I know it's been bored out but I'm unsure of the size
                          O 1 Reply Last reply
                            @ricky0115 markings on top of the piston should give you the size or measure the bore with calipers, either way it's the head off, not a big deal. Personally think your problem lies elsewhere but expect to be proved wrong, see what the garage says, hopefully something simple. Good luck
                            • MightymanM
                              Just had a quick Google and first couple of results suggest worn rings / not correctly sized piston, which makes perfect sense because the sound will be the air squeezing through the ring seal when compression is happening.
                              I suppose this means my bikes could have been a bit down on power not having a correctly sized piston 😂
                              • NottsbikerN
                                NottsbikerN
                                I've had this before on a high mileage DT125R and due to being poor I left it with dire consequences. Basically the piston tried to make its way out via the exhaust port. I went from a standard bore to 2.00mm oversize in one go which made me cry when I realised.
                                • ricky0115R
                                  ricky0115R
                                  ricky0115
                                  Yeah I just tried to ride to work and the engine died doing 60 the back wheel locked up I have never been so scared in my life! I think it's ready for a new top end! Actually anyone selling a wr200 engine?😂
                                  Cheers guys
                                  • MightymanM
                                    Unlucky man, glad your unharmed though!
                                      It's like, the signs were there. It didn't fail for no reason.
                                      You see it all the time where people drive their engines to literal death when the bike was telling them it needed investigating.
                                        ricky0115R
                                        ricky0115R
                                        ricky0115
                                        @mightyman dt125r puff of air from top end didn't find any matches for me😂
                                        • ricky0115R
                                          ricky0115R
                                          ricky0115
                                          wrote on last edited by ricky0115
                                          #23
                                          It's not seized, managed to get it in the garage there's a hole in the piston and some scrapes on the barrel, they advised a full rebuild so I've gone with it. At least it will be done properly and will be under parts warranty!
                                          There goes my new fat bars & koso digital instruments till next month 😞
