  4. DTDR Build
DTDR Build
28 Posts 11 Posters 17.6k Views
  • ZrakoZ Zrako
    @calum oh yes , after Im changed the brake lines for hel braided lines, the standard forks always compressed like crazy ,not cool in the situation when you need stop quickly and whole weight moving over front wheel.
    @zrako heavier fork oil has improved mine no end
    • N notgotaclue
      hello yam all the way lol
      son has a yamaha dt 125x 2007
      standard why change swing arm and front shocks
      how much do they change things for riding and handling
      Yamboy46Y
      Yamboy46Y
      Yamboy46
      @notgotaclue to be honest mate I wanted to reduce the bikes weight (and the wr200 swinger just looks mean lol!!
      I also found the DTR forks to be like Pogo sticks under the force of sharp breaking.
      • Yamboy46Y Yamboy46
        @tdrgreg2 How do the MX 125 USD's, compare lengthwise to the stock forks? Ie. Does the front sit at about the same height as standard??
        Yamboy46Y 1 Reply Last reply
          Yamboy46Y
          Yamboy46Y
          Yamboy46
          @cyber-ninja they around 1to2 inches longer mate,but soon level out with a 17" rim up front
            @declan no mate the spacer was custom made on a lathe.
            if you run a kickstart only DT I believe you can then do away with the battery box and run a capacitor. I also think to my knowledge the shock will go on but the top mounts will need changing and you would have to use the wr linkage,bearing in mind this will Jack up the arse end extremely leaving you to lower it.
            ricky0115R
            ricky0115R
            ricky0115
            wrote on last edited by ricky0115
            @tdrgreg2 Do you have the dimensions for the spacer? I just got a whole MX125 front end for £100 shipped! Also, can i fit a knobbly tyre on the front as i dont fancy a supermoto setup?
            • V
              V
              vtrn_raptor
              You'd need aprilia rx 125 forks for a nobly set up as the brake is positioned higher for the bigger disk on the sm wheel
              ricky0115R 1 Reply Last reply
              • V vtrn_raptor
                ricky0115R
                ricky0115R
                ricky0115
                @vtrn_raptor sorry, why would a tyre make any difference to the braking system? I don't have much understanding of bikes lol
                • V
                  V
                  vtrn_raptor
                  Basically the supermoto wheels have bigger disks so need the brake position in a Different place to the off-road wheels
                  • V
                    V
                    vtrn_raptor
                    I stand corrected theirs a bracket on the mx calliper so with the rx bracket would fit fine
                    • V vtrn_raptor
                      ricky0115R
                      ricky0115R
                      ricky0115
                      @vtrn_raptor oh I get you now, thanks man
                      • Yamboy46Y
                        Yamboy46Y
                        Yamboy46
                        I will try find my design and measurements my friend and send it over to you, however I can't promise anything because I have just moved house so it's a job of finding it at the moment . bare with me please
                        • Yamboy46Y
                          Yamboy46Y
                          Yamboy46
                          What do you guys think of the colour scheme ?
                            @tdrgreg2 Any new pics or is it still mostly all black???
                            • Yamboy46Y
                              Yamboy46Y
                              Yamboy46
                              Some time later my picture finally uploads lol sorry to keep y'all waiting.
                                @tdrgreg2 Oh that's different.
                                Oh yeah feel free to use your own hosting, like your photos upload through my like 2mb upload pipe so I can image it is properly slow.
                                  @tdrgreg2 Looks damn good to me dude, very motocrossy I must say. Top job :thumbsup_tone3:
                                    Here is the bike so far, any questions you have feel free to ask 😊0_1504793560030_IMG_20170907_150803.jpg 0_1504793577805_IMG_20170907_150726.jpg
                                    Stensar
                                    @Yamboy46 Hey sick build is it possible to get the measurements or the file you used to make the spacer? thanks in advance mate
                                    • S Stensar
                                      @Stensar Doubtful as he hasn't been online for 6 years.
