  4. Pv actions
Pv actions
39 Posts 5 Posters 6.5k Views
    @calum lol me too goodnight
    @irongamer727 hahaha you lot crack me up
      I really hope this is not a dick contest, I would have to find my white flag...
      • J Jens Eskildsen
        @jens-eskildsen I really wouldn’t public masterbation is a crime you know... hahaha
        • Irongamer727I
          https://youtu.be/TTbCzADk2jY
          Have a look at this. Bike is missing power at WOT. There's also a substantial amount of oil here. Seems to have leaked past the o rings.
          • Irongamer727I
            https://youtu.be/wTmjo3SzWUk
            Yet this looks pretty damn spot on
              @irongamer727 maybe it’s my eyes but that pv looks way out to me
                @declan ye it's spot on mate
                • Irongamer727I
                  Anyone care to have a look at the pv video? Is it supposed to move and vibrate that much?
                    @irongamer727 Looks like exhaust gases are leaking past the rubber oring from the bush.
                    That are the bush is excessively worn and needs replacing.
                      @calum probably since it's 500 km from brand new
                      • Irongamer727I
                        It shouldn't be vibrating like so then?
                          @irongamer727 I've not seen that before no. You will wear the mechanism out like that.
                          • MiniaM
                            MiniaM
                            Minia
                            Is the powervalve supposed to open at a set amount of revs? Mine opens just over 6k.
                              Sounds right with 6k
                              • Irongamer727I
                                Has anyone noticed that their bike is a lot louder with the valve pinned? Noticed I BIG difference on mine
                                  @irongamer727 Yeah, the valve muffles the exhaust sound, when you pin it, you're blaring the combustion through the expansion chamber.
                                    @irongamer727 mine seemed to idle a lot healthier pinned
                                      @calum https://youtu.be/TWuDiIHVv4o
                                      What do you think might be causing it to be that loose? Everything, even the screw holding the pv sides together is securely fasten.
                                      • Irongamer727I
                                        It's leaking oil and even exhaust gases..
                                          Yeah, it'll be down on performance if that's the case.
                                          Are you sure the other side of the powervalve is fastened properly?
