  4. Pv actions
Pv actions
39 Posts 5 Posters 6.8k Views
  • Irongamer727I
    https://youtu.be/wTmjo3SzWUk
    Yet this looks pretty damn spot on
      @irongamer727 maybe it’s my eyes but that pv looks way out to me
        @declan ye it's spot on mate
        • Irongamer727I
          Anyone care to have a look at the pv video? Is it supposed to move and vibrate that much?
            @irongamer727 Looks like exhaust gases are leaking past the rubber oring from the bush.
            That are the bush is excessively worn and needs replacing.
              @calum probably since it's 500 km from brand new
              • Irongamer727I
                It shouldn't be vibrating like so then?
                  @irongamer727 I've not seen that before no. You will wear the mechanism out like that.
                  • MiniaM
                    MiniaM
                    Minia
                    Is the powervalve supposed to open at a set amount of revs? Mine opens just over 6k.
                      Sounds right with 6k
                      • Irongamer727I
                        Has anyone noticed that their bike is a lot louder with the valve pinned? Noticed I BIG difference on mine
                          @irongamer727 Yeah, the valve muffles the exhaust sound, when you pin it, you're blaring the combustion through the expansion chamber.
                            @irongamer727 mine seemed to idle a lot healthier pinned
                              @calum https://youtu.be/TWuDiIHVv4o
                              What do you think might be causing it to be that loose? Everything, even the screw holding the pv sides together is securely fasten.
                              • Irongamer727I
                                It's leaking oil and even exhaust gases..
                                  Yeah, it'll be down on performance if that's the case.
                                  Are you sure the other side of the powervalve is fastened properly?
                                    @calum yes. Fasten it extra today
                                      @irongamer727 there's play between the pv and the cylinder. Is that normal?
                                        @irongamer727 No
                                          @irongamer727 No
                                          @calum ideas? Just another thing to complain about to Athena?
