  4. Pv actions
Pv actions
39 Posts 5 Posters 6.8k Views
    I really hope this is not a dick contest, I would have to find my white flag...
    • J Jens Eskildsen
      @jens-eskildsen I really wouldn’t public masterbation is a crime you know... hahaha
      • Irongamer727I
        https://youtu.be/TTbCzADk2jY
        Have a look at this. Bike is missing power at WOT. There's also a substantial amount of oil here. Seems to have leaked past the o rings.
        • Irongamer727I
          https://youtu.be/wTmjo3SzWUk
          Yet this looks pretty damn spot on
            @irongamer727 maybe it’s my eyes but that pv looks way out to me
              @declan ye it's spot on mate
              • Irongamer727I
                Anyone care to have a look at the pv video? Is it supposed to move and vibrate that much?
                  @irongamer727 Looks like exhaust gases are leaking past the rubber oring from the bush.
                  That are the bush is excessively worn and needs replacing.
                    @calum probably since it's 500 km from brand new
                    • Irongamer727I
                      It shouldn't be vibrating like so then?
                        @irongamer727 I've not seen that before no. You will wear the mechanism out like that.
                        • MiniaM
                          MiniaM
                          Minia
                          Is the powervalve supposed to open at a set amount of revs? Mine opens just over 6k.
                            Sounds right with 6k
                            • Irongamer727I
                              Has anyone noticed that their bike is a lot louder with the valve pinned? Noticed I BIG difference on mine
                                @irongamer727 Yeah, the valve muffles the exhaust sound, when you pin it, you're blaring the combustion through the expansion chamber.
                                  @irongamer727 mine seemed to idle a lot healthier pinned
                                    @calum https://youtu.be/TWuDiIHVv4o
                                    What do you think might be causing it to be that loose? Everything, even the screw holding the pv sides together is securely fasten.
                                    • Irongamer727I
                                      It's leaking oil and even exhaust gases..
                                        Yeah, it'll be down on performance if that's the case.
                                        Are you sure the other side of the powervalve is fastened properly?
                                          @calum yes. Fasten it extra today
