tuningdtryamaha2003wr200
254 Posts 25 Posters 243.7k Views 6 Watching
  • Louis-DT-WRL
    Louis-DT-WRL
    Slowly getting it to be how I visioned it.
    Toning it down, exhaust guard on, chain guard powdercoated black, radiator Louvres changed from yellow ones to gun metal grey.
    Just want my mirrors to turn up 😁
    Warning stickers on
      That's looking well smart mate, keep it up!
        Louis-DT-WRL
        Louis-DT-WRL
        @calum thanks, I've been keeping tabs on your rotax project, look forward to hearing it 😎
        • MiniaM
          MiniaM
          Minia
          wrote on last edited by Minia
          #246
          You got any pictures of the old blue and yellow scheme you had? You remember where you got those decals?
          • MiniaM Minia
            Louis-DT-WRL
            Louis-DT-WRL
            @Minia hi, the older pics are near the beginning of thread. DD graphics but I swapped some bits around and added yellow in places
            • Louis-DT-WRL Louis-DT-WR
              And ofcourse I had zeeltronic make the first DT125R CDI for me and for all my help I only had to pay for the handheld reprogrammer
              This was perfect for my project to set the powervalve limits and curve.
              Also great for ignition timing.
              Although they did wire it wrong originally and the powervalve ran backwards 😆
              But soon sorted it.
              BluestoesonnoseB
              BluestoesonnoseB
              Bluestoesonnose
              @Louis-James said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
              But soon sorted it.
              Hi matie,
              What map did you use for the DT200WR top end as I'm starting to build a 125R / 200WR hybrid?
              Cheers
              2002 DT125R
                But soon sorted it.
                Hi matie,
                Cheers
                Louis-DT-WRL
                Louis-DT-WRL
                @Bluestoesonnose hi, I made a custom map
                • BluestoesonnoseB
                  BluestoesonnoseB
                  Bluestoesonnose
                  Cheers, any tips for the ignition timing compared to the DT125R, ie, retard or advance over std?
                  Is it possible to send me a copy of the map as a starter for 10?
                  2002 DT125R
                    Louis-DT-WRL
                    Louis-DT-WRL
                    @Bluestoesonnose from memory I advanced it 3degree in the lower to mid range
                    • BluestoesonnoseB
                      BluestoesonnoseB
                      Bluestoesonnose
                      Many thanks
                      2002 DT125R
                        Many thanks
                        Louis-DT-WRL
                        Louis-DT-WRL
                        @Bluestoesonnose if I remember I'll get my zeeltronic map copied
                        • BluestoesonnoseB
                          BluestoesonnoseB
                          Bluestoesonnose
                          Once again, many thanks
                          2002 DT125R
