tuningdtryamaha2003wr200
254 Posts 25 Posters 240.5k Views 6 Watching
  • Louis-DT-WRL
    Louis-DT-WRL
    Got it back together, just need reflector and number plate bracket, ...mirrors on order.
    • Louis-DT-WRL
      Louis-DT-WRL
      And the tool box is on, balances the rear end with the exhaust silencer nicely.
        I must admit, that is looking pucker!
        Really great photos as well. What camera are you using?
        Irongamer727I Louis-DT-WRL 2 Replies Last reply
          @calum and how does he get them inbedded here directly?
            Louis-DT-WRL
            Louis-DT-WRL
            @calum said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
            Thanks mate, my Huawei mate 10 Pro phone .
            Really shows the attention to detail. Might take the DT out tomorrow along some trails to get some decent pictures, test ride then get my head down for the big bike test after my holiday next month 😎 spare up some cash
              Louis-DT-WRL
              Louis-DT-WRL
              @irongamer727 said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
              If Callum had a pound for every time he was asked this 🤣 there's a tutorial, very simple, just use a good host site like imgur
              • Louis-DT-WRL Louis-DT-WR
                @louis-james 😛
                • Louis-DT-WRL
                  Louis-DT-WRL
                  Slowly getting it to be how I visioned it.
                  Toning it down, exhaust guard on, chain guard powdercoated black, radiator Louvres changed from yellow ones to gun metal grey.
                  Just want my mirrors to turn up 😁
                  Warning stickers on
                    That's looking well smart mate, keep it up!
                      Louis-DT-WRL
                      Louis-DT-WRL
                      @calum thanks, I've been keeping tabs on your rotax project, look forward to hearing it 😎
                      • MiniaM
                        MiniaM
                        Minia
                        wrote on last edited by Minia
                        #246
                        You got any pictures of the old blue and yellow scheme you had? You remember where you got those decals?
                        • MiniaM Minia
                          Louis-DT-WRL
                          Louis-DT-WRL
                          @Minia hi, the older pics are near the beginning of thread. DD graphics but I swapped some bits around and added yellow in places
                            And ofcourse I had zeeltronic make the first DT125R CDI for me and for all my help I only had to pay for the handheld reprogrammer
                            This was perfect for my project to set the powervalve limits and curve.
                            Also great for ignition timing.
                            Although they did wire it wrong originally and the powervalve ran backwards 😆
                            But soon sorted it.
                            BluestoesonnoseB
                            BluestoesonnoseB
                            Bluestoesonnose
                            @Louis-James said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
                            But soon sorted it.
                            Hi matie,
                            What map did you use for the DT200WR top end as I'm starting to build a 125R / 200WR hybrid?
                            Cheers
                            2002 DT125R
                              But soon sorted it.
                              Hi matie,
                              Cheers
                              Louis-DT-WRL
                              Louis-DT-WRL
                              @Bluestoesonnose hi, I made a custom map
                              • BluestoesonnoseB
                                BluestoesonnoseB
                                Bluestoesonnose
                                Cheers, any tips for the ignition timing compared to the DT125R, ie, retard or advance over std?
                                Is it possible to send me a copy of the map as a starter for 10?
                                2002 DT125R
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  @Bluestoesonnose from memory I advanced it 3degree in the lower to mid range
                                  • BluestoesonnoseB
                                    BluestoesonnoseB
                                    Bluestoesonnose
                                    Many thanks
                                    2002 DT125R
                                      Many thanks
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      @Bluestoesonnose if I remember I'll get my zeeltronic map copied
                                      • BluestoesonnoseB
                                        BluestoesonnoseB
                                        Bluestoesonnose
                                        Once again, many thanks
                                        2002 DT125R
