tuningdtryamaha2003wr200
254 Posts 25 Posters 240.5k Views 6 Watching
    I must admit, that is looking pucker!
    Really great photos as well. What camera are you using?
    @calum and how does he get them inbedded here directly?
      Louis-DT-WRL
      Louis-DT-WRL
      @calum said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
      Thanks mate, my Huawei mate 10 Pro phone .
      Really shows the attention to detail. Might take the DT out tomorrow along some trails to get some decent pictures, test ride then get my head down for the big bike test after my holiday next month 😎 spare up some cash
        Louis-DT-WRL
        Louis-DT-WRL
        @irongamer727 said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
        If Callum had a pound for every time he was asked this 🤣 there's a tutorial, very simple, just use a good host site like imgur
        • Louis-DT-WRL Louis-DT-WR
          @louis-james 😛
          • Louis-DT-WRL
            Louis-DT-WRL
            Slowly getting it to be how I visioned it.
            Toning it down, exhaust guard on, chain guard powdercoated black, radiator Louvres changed from yellow ones to gun metal grey.
            Just want my mirrors to turn up 😁
            Warning stickers on
              That's looking well smart mate, keep it up!
                Louis-DT-WRL
                Louis-DT-WRL
                @calum thanks, I've been keeping tabs on your rotax project, look forward to hearing it 😎
                • MiniaM
                  MiniaM
                  Minia
                  wrote on last edited by Minia
                  #246
                  You got any pictures of the old blue and yellow scheme you had? You remember where you got those decals?
                  • MiniaM Minia
                    Louis-DT-WRL
                    Louis-DT-WRL
                    @Minia hi, the older pics are near the beginning of thread. DD graphics but I swapped some bits around and added yellow in places
                      And ofcourse I had zeeltronic make the first DT125R CDI for me and for all my help I only had to pay for the handheld reprogrammer
                      This was perfect for my project to set the powervalve limits and curve.
                      Also great for ignition timing.
                      Although they did wire it wrong originally and the powervalve ran backwards 😆
                      But soon sorted it.
                      BluestoesonnoseB
                      BluestoesonnoseB
                      Bluestoesonnose
                      @Louis-James said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
                      But soon sorted it.
                      Hi matie,
                      What map did you use for the DT200WR top end as I'm starting to build a 125R / 200WR hybrid?
                      Cheers
                      2002 DT125R
                        But soon sorted it.
                        Hi matie,
                        Cheers
                        Louis-DT-WRL
                        Louis-DT-WRL
                        @Bluestoesonnose hi, I made a custom map
                        • BluestoesonnoseB
                          BluestoesonnoseB
                          Bluestoesonnose
                          Cheers, any tips for the ignition timing compared to the DT125R, ie, retard or advance over std?
                          Is it possible to send me a copy of the map as a starter for 10?
                          2002 DT125R
                            Louis-DT-WRL
                            Louis-DT-WRL
                            @Bluestoesonnose from memory I advanced it 3degree in the lower to mid range
                            • BluestoesonnoseB
                              BluestoesonnoseB
                              Bluestoesonnose
                              Many thanks
                              2002 DT125R
                                Many thanks
                                Louis-DT-WRL
                                Louis-DT-WRL
                                @Bluestoesonnose if I remember I'll get my zeeltronic map copied
                                • BluestoesonnoseB
                                  BluestoesonnoseB
                                  Bluestoesonnose
                                  Once again, many thanks
                                  2002 DT125R
