  3. DTRE
  4. Whats a good carburetor for my DT125 with a 170cc athena cylinder kit?
carburetor
28 Posts 7 Posters 13.4k Views 1 Watching
    @claws Well you've definitely got more money than me.
    Once upon a time my brother ran a kehien 38 on his 170 Athena. The fueling was mental and the performance did not match.
    That's just my advice, you don't have to take it. Bigger is not always better. You'd do well to lower it to get more performance and fuel economy.
    My brother is currently running a 34mm on a 170cc two stroke, and he's looking at a 28mm for more performance and better economy.
    clawsC
    clawsC
    claws
    @Calum i cant really tune my current carb and i dont have that much money haha
    • clawsC claws
      @claws You're throwing good money after bad, a few jets is considerably cheaper than a 36mm carb. Besides, do you really think slapping on a carb will make your bike run right?
      Fueling is no something you scrimp on, run it lean, and you'll run into detonation destroying both the bottom and top end. So don't scrimp on fueling.
      clawsC 1 Reply Last reply
        clawsC
        clawsC
        claws
        @Calum getting the keihin for 60 euros isnt a bad deal besides the screws for the carburetor are seized so i cant mess with the float or jets. also i can just sell the carb if i need to. im not an expert at tuning carbs but i can make it run ok
        • clawsC claws
          @claws It needs to run spot on, is my point. Even the new carb will need jetting.
          O clawsC 2 Replies Last reply
            @Calum said in Whats a good carburetor for my DT125 with a 170cc athena cylinder kit?:
            I second that
              clawsC
              clawsC
              claws
              @Calum gonna get it running great. better than with the original carb
              • clawsC claws
                @claws That's great to hear! I know from experience going too big is detrimental. But maybe I didn't spend enough time tweaking it!
                  clawsC
                  clawsC
                  claws
                  @Calum wouldnt be making any sense to not get it running great. gonna send a video of it running later
                  DartyD 1 Reply Last reply
                  • clawsC claws
                    @claws alt text
                    Not to sound boring, but, Keihin PWK 36mm of a KDX220
                    Been there done that, mental, makes no sense. Actually slower overall..
                    A 32mm can be spot on, if you like to 'hoon' constantly, but these engines are fussy to jet on a bigger carb, I don't recommend it.
                    CalumC clawsC 2 Replies Last reply
                    3
                      @claws alt text
                      @Darty Long time no post 😛
                        @claws alt text
                        clawsC
                        clawsC
                        claws
                        @Darty cant be slower than now though
                        CalumC DartyD 2 Replies Last reply
                        • clawsC claws
                          @claws You'd be surprised.
                          I'm not going into the specifics.
                          But Pressure=force/area
                          The force is generated via the vacuum of the engine, the area is the size of the carb.
                          If the carb increases sizes, but the vacuum remains the same then you will see a drop in pressure. Aka, the pressure to actuate the carb will lower and it may not be as effective, sine the carb works off the venturi effect, getting this balance right is important. Going too big can have adverse affects. Is 36mm too big? I'm not saying that, I'm just saying bigger is not always better.
                            clawsC
                            clawsC
                            claws
                            @Calum of course a bigger carburetor isnt always better but i dont think that i can go slower with the keihin and if i cant get it to run great with the bike i will trade it for a smaller one. but a guy that i know put a 38mm carb in his 1998 dt125r and said that it runs great. still i believe that the new carburetor will out perform the one i have now but if it doesnt i will be a bit disappointed but anyways i wont lose anything with this new carb
                              Oh yeah! Report back to us your findings 😃
                              • clawsC claws
                                wrote on last edited by Darty
                                #21
                                @claws True, but don't forget you'll make less power under 6-8k Rpm.
                                @Calum lol I don't have much to say about these bikes anymore
                                clawsC CalumC declanD NINJAN 4 Replies Last reply
                                  clawsC
                                  clawsC
                                  claws
                                  @Darty doesnt matter. it doesnt have much torque in the lower rpms but its because my ypvs is locked to the up right position. gonna get it resolved as well and maybe get an athena pipe for the bike since its made for the 170cc cylinder kit
                                  • Glynn123G
                                    Glynn123G
                                    Glynn123
                                    Jetting a none standard carb on a DT is a ballache, 32mm polini pwk didn't make my DT much faster at all without any supporting mods like ignition etc. The fuel usage was well over double too even with both carbs appropriately jetted.
                                      @Darty Join the club. But most of us talk about different projects these days.
                                        @Darty we kinda miss ya around here
                                          @Darty Which bikes are you currently working on/involved with ATM then dude???
