The Leviathan Project
@aidan1996 WTF has he done to that bike to get it up to nearly 1700RPM???
@Calum i'm also attempting to put the yz125 forks on my dt125r.
would you be interested in making another bearing cup for the top bearing that i could buy from you?
Love these sort of hand guards. Made up something similar to go on my DR-Z. Looked good I thought.
@Mightyman I've got the similar ones , Zeta makes them. Looks cool mate
Snail trail pace, but it's getting there!
This piece I had to make up as the radiator swap meant these had to be cabled tied togeteher in one piece.
Sorry to refer back to the start of the thread, but, have you still got the how-to for the kickstart mod? And does it replace the electric start or can you keep both?
@finnerz89 Keep both. The tutorial is on here bud try searching for it.
@Calum did you see my post about the bearing cup?
@gareth_iowc Yeah I did write a reply. Must have forgot to send it.
Basically it's not as simple as: grab a YZ that'll do
There is a bit more to it. Diagrams have to be made, measurements have to be made and having the physical item to hand always helps.
I also no longer have access to the lathe I used last time. I need to rewire the current lathe I have got.
So no I can't I'm afraid. I've written full guidance on how it can be done.
If I had a working lathe then it's possible. But it took me a fair few hours last time due to the inferior tools. An engineering firm should be able to CnC it in minutes if you draw up a diagram for them.
Ok man thanks.
I've got a guy in mind but I thought you might be with a try as you've done one before
Ok man thanks.
@gareth_iowc I wrote a guide on the basic theory. Follow that and you can't go too far.
Two long years
Shit hot
when ours should have a stand together at a show
Two long years
@CYBER-NINJA It's a fresh engine, so that'll be the oil used on assembly.
@Mightyman Nah not yet. There is still a fair amount of work to be done. But it's nice that it's all back up together and can be started. -
Hmmm i still cant decide which pipe to have off Romeu, i do like the look of the underslung one.
Sounds sweet though dude!
@finnerz89 It's not for everyone. I love it. But I love being different.
Just interested. I read you doubted the porting on the cylinder right? But it turned out to be good? Do you remember what it cost?
