  4. Clear Carb Warming Hoses
27 Posts 9 Posters 9.3k Views 1 Watching
    @Jens-Eskildsen Yeah mate, sure. That's when you notice the oil pump is driven off a plastic cog which is twenty years old...
    Clear pipe will let you straight away if that pump has failed.
    B
    B
    Bentley
    @Calum I might have to look at getting some clear lines, as my Dt still has the oil pump and it did come on for a few secounds when riding can be parannoying.
    • B
      B
      Bentley
      Anyone got a link where to buy them?
      • F
        http://yambits.co.uk/dt125x-clear-oil-line-kit-p-42285.html
        B 1 Reply Last reply
          B
          B
          Bentley
          @finnerz89 thanks mate! 🙂
          • MightymanM
            Finally got a picture with the coolant inside the loop!
            • MightymanM Mightyman
              @Mightyman OOOHHH that rust sure needs sorting dude, takes the edge off them pukka coolant pipes for-sure!!!
              MightymanM 1 Reply Last reply
                @CYBER-NINJA aha yeah.. one day I'll pull it apart and spray the frame.. but the majority of the bike is either rusty, dirty or broken(plastics) so not really worth the time.
                • ZrakoZ
                  ZrakoZ
                  Zrako
                  Rust remedy and spray it with some protective paint . Will do for some time . Dont like patching but it should stop rust biting your precious bike 😄
                  1979 Jawa Mustang 50
                  2003 Gilera DNA 125 R.I.P
                  2015 Keeway TX 125 SM
                  2006 Yamaha DT 125 X
                    So, i bought some clear pipe, and installed it on the oil feed line, so a bit of bling, and a bit more pink for the bike aswell
                    Theres not much flow in the carb-warming pipes, i see some air in there, so I guess I need to bleed them a bit more, and see if that will help.
                    Then raced it at a small mx track:
                    CalumC MightymanM 2 Replies Last reply
                    • J Jens Eskildsen
                      @Jens-Eskildsen looking lovely mate!
                      • J Jens Eskildsen
                        @Jens-Eskildsen mine had air for the first couple minutes of running before it bled itself up.
                        • rogeringR
                          rogeringR
                          rogering
                          What mm is the carb cooling tubes ? I see the 2t oil is 3mm thanks in advance
                          • rogeringR rogering
                            6mm for these carb coolant pipes.
