  3. Carburetor
  4. Cutting top of airbox
16 Posts 9 Posters 3.3k Views
  • rogeringR Offline
    rogeringR Offline
    rogering
    Cutting top of airbox as my bikes for pure off road / greenlaning so what's the pros and cons from experienced members
      I have been informed by Rob @ Yamaha Skellerns Cheltenham, if you're going to do it, cut the whole top off.
      So long as you jet it accordingly, it'll be a derestriction.
      • rogeringR Offline
        rogeringR Offline
        rogering
        Thanks calum I have a 240 jet and my exhaust has restrictor removed also as I rewired my own loom blue is earthed and I had diamond pv and positiond into de restricted position, so with cutting top off what up jet would you say I should go to mate ?
        • Louis-DT-WRL Offline
          I've done it, even with the 125 engine and standard carb. Ran very well and sounds great 🙂
          • A Offline
            A Offline
            andrewj1680
            Mine didn't like too much air I've had to seal Some of the hole back up and I'm running a full dep exhaust carbon reeds and a 250 main jet
              Well I personally think it's butchering the bike. Personally I just use a pod filter.
              • rogeringR Offline
                rogeringR Offline
                rogering
                True mate I have a pod filter but as mine just for off road I need a level of water protection but only got airbox but you have thankfully sorted out the boot I needed for cars to box an I'm greatfull for mate
                  My stock bike runs better with the snorkel removed, and the hole in the airbox enlarged.
                  I have added a little splash guard to keep the water away from the opening.
                  • Glynn123G Offline
                    Glynn123G Offline
                    Glynn123
                    I know this is old, but to help future readers, I have very good results with snorkle removed and 250 main jet, this is paired with a full system.
                    • Glynn123G Glynn123
                      @glynn123 does the snorkel just pull out lads
                      R 1 Reply Last reply
                      • NottsbikerN Offline
                        NottsbikerN Offline
                        Yes, might be glued in like the airbox halves are glued / screwed together
                        • Glynn123G Offline
                          Glynn123G Offline
                          Glynn123
                          Should just pull out, will be stiff due to the big lip mind, mine came out fine.
                            @glynn123 just asking since when I tried I couldn’t get it out and didn’t want to rip it
                              Put a flat blade between the air box and snorkel and leverage it out. Don't just tug it out.
                              Personally I prefer my bikes with Snorkels in as they ride better.
                                @calum thanks man and yeah worth a try though while I have it apart
                                  R Offline
                                  R Offline
                                  ryancole2001
                                  @declan yes it pulls right out
