  3. Other
  4. Re booting the sm 50 am6 project
24 Posts 5 Posters 7.6k Views 1 Watching
  • MightymanM
    I think these are great looking bikes. I want to pick up a project one someday and stick a 125 engine into it.
    • MightymanM Mightyman
      @Mightyman I wanted a dt engine in it the mounts are nearly the same but just can't afford one
        @declan just stripped all the wires to get rid of clutter and potential broken wires
          @declan @Calum how tight should the seal be around a clutch push rod mines leaking on a new seal and it's not very tight it's seals it but give not resistance sliding down the shaft?
            @declan make that clearer it's full wrapped around the shaft but it's not a very tight seal what do you think?
              @declan There should be some resistance bud.
                @Calum hmmm okay maybe I'll try getting a new one now would you reckon my clutch plates need changing since I lose all power past 2nd gear?
                  @declan You would have to measure their thickness and check it against the specified tolerances
                    @Calum thanks for your time.
                      Fired right up and running good more to follow
                        @Calum i believe that my power problem is severe clutch drag as the lever only has around 2 inches of pull and it's no where near enough
                          @Calum gotta love that sound
                          https://youtu.be/SdjEarivTtM
                          • MightymanM
                            very nice 👍
                              very nice 👍
                              @Mightyman thank you hopefully it actually rides now and if it does there will soon be a nice big bore on it
                                I had a proper Minarelli AM6 CH Racing WXE50 when I was 16.
                                It had a 12mm Dellorto Carb!! lol
                                It only did 55mph, but it was the fastest 50cc to get there I've ever known.
                                I'll always miss this motorcycle...
                                  @Darty mines struggling for power I've now sorted the clutch but it's still struggling not sure what it could be, the carb on this is like. A pea shooter lol
                                    @Darty Pretty sure my RS had a bigger carb than that at 20mm...
                                    declanD 2 Replies Last reply
                                      @Calum if memory serves me I've got a dellorto 17.5 auto choke model but converted to manual
                                        @declan 2T screamer - the best motorbike sound for-sure!!! 😉
                                          @CYBER-NINJA sure is lol
