  3. Other
  4. Re booting the sm 50 am6 project
24 Posts 5 Posters 7.0k Views 1 Watching
    @Mightyman I wanted a dt engine in it the mounts are nearly the same but just can't afford one
    @declan just stripped all the wires to get rid of clutter and potential broken wires
      @declan @Calum how tight should the seal be around a clutch push rod mines leaking on a new seal and it's not very tight it's seals it but give not resistance sliding down the shaft?
        @declan make that clearer it's full wrapped around the shaft but it's not a very tight seal what do you think?
          @declan There should be some resistance bud.
            @Calum hmmm okay maybe I'll try getting a new one now would you reckon my clutch plates need changing since I lose all power past 2nd gear?
              @declan You would have to measure their thickness and check it against the specified tolerances
                @Calum thanks for your time.
                  Fired right up and running good more to follow
                    @Calum i believe that my power problem is severe clutch drag as the lever only has around 2 inches of pull and it's no where near enough
                      @Calum gotta love that sound
                      https://youtu.be/SdjEarivTtM
                      N 1 Reply Last reply
                      • MightymanM Offline
                        MightymanM Offline
                        very nice πŸ‘
                        • MightymanM Mightyman
                          very nice πŸ‘
                          @Mightyman thank you hopefully it actually rides now and if it does there will soon be a nice big bore on it
                          • DartyD Offline
                            DartyD Offline
                            I had a proper Minarelli AM6 CH Racing WXE50 when I was 16.
                            It had a 12mm Dellorto Carb!! lol
                            It only did 55mph, but it was the fastest 50cc to get there I've ever known.
                            I'll always miss this motorcycle...
                              @Darty mines struggling for power I've now sorted the clutch but it's still struggling not sure what it could be, the carb on this is like. A pea shooter lol
                                @Darty Pretty sure my RS had a bigger carb than that at 20mm...
                                declanD 2 Replies Last reply
                                  @Calum if memory serves me I've got a dellorto 17.5 auto choke model but converted to manual
                                    N Offline
                                    N Offline
                                    @declan 2T screamer - the best motorbike sound for-sure!!! πŸ˜‰
                                    • N NINJA
                                      @CYBER-NINJA sure is lol
                                        #24
                                        @calum https://youtu.be/XCyGlj3gCgM.
                                        Finally got an airbox assembly and it’s running okay it did seem to pull better haven’t tried it properly I’ll keep you posted
