  4. Thermo unit Earthing help required.
16 Posts 5 Posters 3.6k Views
  • Yamboy46Y Offline
    Yamboy46Y Offline
    Yamboy46
    wrote on last edited by Yamboy46
    Good morning forum,
    Can anybody help me find where I need to place this thermo unit earth connector on the frame ?
    Many thanks in advance.
    • ZrakoZ Offline
      ZrakoZ Offline
      Zrako
      wrote on last edited by Zrako
      Never heard of temp sensor with earth.
      To be honest the terminal looks like from battery but wire is too small for it.
      1979 Jawa Mustang 50
      2003 Gilera DNA 125 R.I.P
      2015 Keeway TX 125 SM
      2006 Yamaha DT 125 X
        If it's an earth wire, then anywhere on the frame will suit.
        • F Offline
          F Offline
          I think that should go on one of the regulator mounting bolts. Under the RH side scoop
          • Yamboy46Y Offline
            Yamboy46Y Offline
            Yamboy46
            Cheers chaps I'll get that homed immediately , also I don't suppose any of you gents would have any idea to as why when I connect the battery the starter motor turns itselfs weather the keys are in the ignition or not?
            F 1 Reply Last reply
            • Yamboy46Y Yamboy46
              F Offline
              F Offline
              @tdrgreg2 starter relay might be stuck closed
              Yamboy46Y CalumC 2 Replies Last reply
                Yamboy46Y Offline
                Yamboy46Y Offline
                Yamboy46
                @finnerz89 could you please go further in depth
                  @finnerz89 Would it though? Because the starter button is switch live is it not?
                    F Offline
                    F Offline
                    @calum yeah, it has a direct feed from the battery, if the contacts inside are welded together then as soon as you put power to it the motors going to turn
                      @finnerz89 Sorry I thought he meant that the button works if the switch is on or off.
                      Just read it again, yeah what you said sounds about right
                        F Offline
                        F Offline
                        @calum needs a twat with a hammer as we say in the trade!
                        I'm usually the twat 🤣
                        • NottsbikerN Offline
                          NottsbikerN Offline
                          Does this mount to the coil bolt. Looks like it fits onto something. The loom on the Belgarda TDR is slightly different to the DTR ones.
                          • NottsbikerN Nottsbiker
                            F Offline
                            F Offline
                            @nottsbiker I thought regulator mount, looks like the one on my DTX. Either way anywhere on the frame should do
                              NottsbikerN Offline
                              Regulator mounts differently on the TDR to the X. Yours iirc it's on the rad frame and the TDR one fits like the DTR under the seat and is held on with a screw that doesn't hold anything else on
                              Yamboy46Y 1 Reply Last reply
                                Yamboy46Y Offline
                                Yamboy46Y Offline
                                Yamboy46
                                @nottsbiker would you happen to know how the starter relay is wired up . Amy pictures would be a bonus.
                                  NottsbikerN Offline
                                  Is it not in that pdf i sent out last week?
                                  Iirc it's connected to the battery via a heavy duty red (positive) cable which then goes to the starter motor. I think that the black (earth) cable goes from the battery to the solenoid then from there attaches to the engine. There is also a two wire plug that goes to the solenoid which is the lower power switching signal which is connected to the starter button.
                                  No pics I'm afraid I'm away on holiday at mo
