  3. DTRE
  4. The Leviathan Project
4dlzeeltronicdtreleviathanbelgarda
136 Posts 25 Posters 121.2k Views 4 Watching
    @aidan1996 WTF has he done to that bike to get it up to nearly 1700RPM???
    @CYBER-NINJA It reving to that rpm and it making any power at all are two completely different things. My CDI allows sparking up to 22'000. But it woild make less power there than it would at 5.
      Snail trail pace, but it's getting there!
      This piece I had to make up as the radiator swap meant these had to be cabled tied togeteher in one piece.
      alt
      alt
      alt
      alt
      • G
        G
        gareth_iowc
        @Calum i'm also attempting to put the yz125 forks on my dt125r.
        would you be interested in making another bearing cup for the top bearing that i could buy from you?
        DT125R 2000
        DRZ400 2006
        Golf Mk3 20v Turbo 1996
        • MightymanM Mightyman
          Love these sort of hand guards. Made up something similar to go on my DR-Z. Looked good I thought.
          https://www.youtube.com/watch?v=Nd4YsMG4ocU
          ZrakoZ
          ZrakoZ
          Zrako
          @Mightyman I've got the similar ones , Zeta makes them. Looks cool mate 👍
          1979 Jawa Mustang 50
          2003 Gilera DNA 125 R.I.P
          2015 Keeway TX 125 SM
          2006 Yamaha DT 125 X
            alt
            alt
            alt
            alt
            @Calum Looks neat bud. 👍
            • F
              F
              Sorry to refer back to the start of the thread, but, have you still got the how-to for the kickstart mod? And does it replace the electric start or can you keep both?
              • F finnerz89
                @finnerz89 Keep both. The tutorial is on here bud try searching for it.
                F 1 Reply Last reply
                  F
                  F
                  @Calum Cheers mate
                  • G
                    G
                    gareth_iowc
                    @Calum did you see my post about the bearing cup? 🙂
                    DT125R 2000
                    DRZ400 2006
                    • G gareth_iowc
                      @gareth_iowc Yeah I did write a reply. Must have forgot to send it.
                      Basically it's not as simple as: grab a YZ that'll do
                      There is a bit more to it. Diagrams have to be made, measurements have to be made and having the physical item to hand always helps.
                      I also no longer have access to the lathe I used last time. I need to rewire the current lathe I have got.
                      So no I can't I'm afraid. I've written full guidance on how it can be done.
                      If I had a working lathe then it's possible. But it took me a fair few hours last time due to the inferior tools. An engineering firm should be able to CnC it in minutes if you draw up a diagram for them.
                      • G
                        G
                        gareth_iowc
                        Ok man thanks.
                        I've got a guy in mind but I thought you might be with a try as you've done one before 🙂
                        DT125R 2000
                        DRZ400 2006
                        • G gareth_iowc
                          Ok man thanks.
                          @gareth_iowc I wrote a guide on the basic theory. Follow that and you can't go too far.
                            Two long years
                            https://youtu.be/n8NCG4xdbqY
                            5
                            • Louis-DT-WRL
                              Louis-DT-WRL
                              Louis-DT-WR
                              Shit hot 😍 when ours should have a stand together at a show 💪
                              • MightymanM
                                MightymanM
                                #75
                                You got it back on the road yet @Calum? Sounds sweet, show us some more!
                                  Two long years
                                  @Calum Looks cool bud, she's a bit smokey tho, was it a cold start???
                                    @CYBER-NINJA It's a fresh engine, so that'll be the oil used on assembly.
                                    @Mightyman Nah not yet. There is still a fair amount of work to be done. But it's nice that it's all back up together and can be started.
                                    • F
                                      F
                                      Hmmm i still cant decide which pipe to have off Romeu, i do like the look of the underslung one.
                                      Sounds sweet though dude!
                                      • F finnerz89
                                        @finnerz89 It's not for everyone. I love it. But I love being different.
                                        • Irongamer727I
                                          Irongamer727I
                                          Just interested. I read you doubted the porting on the cylinder right? But it turned out to be good? Do you remember what it cost?
