  4. Clutch
Clutch
67 Posts 7 Posters 22.6k Views 2 Watching
  • MightymanM Offline
    MightymanM Offline
    Image taken from sv650 forum. This is what the notches will look like. I doubt it will be as severe as this picture, but the notches shouldn't be there, it should look nice and smooth.
    • MightymanM Mightyman
      @Ricky Oh! In that case, definitely could be a notched basket as @Jens-Eskildsen mentioned... Check out the walls of the basket where the edges of the friction plates slide into. If there are notches this would explain your low rev issue.
      RickyR Offline
      RickyR Offline
      Ricky
      @Mightyman but I don't understand why it only started since i put the new clutch in it never did it with the old clutch
      DT 125X
        MightymanM Offline
        #43
        It COULD have been triggered by you changing the gear oil.
        EDIT:
        Or possibly the old plates had already worn enough to somehow make the issue less prominent... Why did you change the clutch in the first place? Could you give the old bits a try just to confirm it's not the assembly that's incorrect?
        RickyR 1 Reply Last reply
          EDIT:
          RickyR Offline
          RickyR Offline
          Ricky
          wrote on last edited by Ricky
          #44
          @Mightyman these are the old 1s I changed it because it wasn't going in gear and sometimes it would get stuck in gear so when I'd pull up it wouldn't shift up or down until i turned the engine off then it would move easy
          DT 125X
          MightymanM 1 Reply Last reply
          • RickyR Ricky
            MightymanM Offline
            MightymanM Offline
            @Ricky That's also consistent with a notched basket if I'm not mistaken.. Maybe your issue the whole time hasn't been the plates, but rather the basket. If the notches aren't too deep, try to file them down and see if it performs any better.
              It not going into gear could be a variety of things. Worn selector forks, bearings, clutch assembly, clutch springs.
              Sounds to me like the clutch isn't disengaging.
              Again what I said earlier will tell you it is clutch disengagement problem.
              Never heard of a worn basket on a dt before though. Maybe if it ran with no oil. My brother ran his dt gearbox on coolant and oil with no problems. So they are pretty well engineered.
                RickyR Offline
                RickyR Offline
                Ricky
                @Calum I took it to the local bike garage he said it sounds like 1 or both of push rods and ball I've had the bike on its side trying to get them out bit they don't want to come out so I'm going to get a magnet see if that works
                DT 125X
                  MightymanM Offline
                  I replaced mine as I thought they were the cause of a problem I had. Turned out they were fine and didn't have any effect on it. But worth a try for you I suppose!
                    RickyR Offline
                    RickyR Offline
                    Ricky
                    @Mightyman definitely worth a try get all 3 for £20
                    DT 125X
                      MightymanM Offline
                      Do you have a picture of your clutch basket handy, just to rule that out?
                        RickyR Offline
                        RickyR Offline
                        Ricky
                        @Mightyman i will have later when i strip it again
                        DT 125X
                          Push rods and ball bearing. Sounds far fetched to me
                            RickyR Offline
                            RickyR Offline
                            Ricky
                            @Calum I'm going to strip it soon get the ball and rod out to check them and do some more adjustment
                            DT 125X
                            • RickyR Offline
                              RickyR Offline
                              Ricky
                              My ball had 2 flat sides so I've ordered a new 1
                              DT 125X
                                MightymanM Offline
                                #55
                                Wow, hopefully it's your fix man!
                                • RickyR Offline
                                  RickyR Offline
                                  Ricky
                                  Hopefully 0_1485622564300_20170128_165352.jpg 0_1485622590831_20170128_165418.jpg 0_1485622643466_20170128_165433.jpg 0_1485622674961_20170128_165500.jpg
                                  DT 125X
                                    NORFE used to chop up some M6 bolts and use as a bearing....
                                    Not sayinf that's good practice but was good enough for him.
                                    RickyR CalumC 2 Replies Last reply
                                      RickyR Offline
                                      RickyR Offline
                                      Ricky
                                      @Calum I've got some old bearings I was thinking of opening them up see if any are the same size the rods are ok
                                      DT 125X
                                        @Ricky That doesn't look great lol.
                                        You can get the ball bearings off eBay for next to nothing..
                                          RickyR Offline
                                          RickyR Offline
                                          Ricky
                                          @Calum I've ordered 1 from yambits I was playing with the bearing idea as there can't be any difference surely
                                          DT 125X
