  4. Yamaha DT125R '01 - Running Project
portingignitech4dldtrwr200
135 Posts 27 Posters 141.9k Views 6 Watching
  • DartyD Darty
    Global pandemic huh? returns to shed
    Not been doing alot, just wanted to share some bits.
    After 4 years, finally built a proper DTX Brembo Caliper conversion. Threw some Titanium bolts on for some weight saving, and bling.
    Custom Bracket and Spacers made, was fun on the old Myford Lathe. Got to force yourself to work in Imperial though...,
    Plenty of braking power with Ceramic Pads on a 298mm Disc. To manage the DTR Fork, I've rebuilt them with 15W Oil and 35mm Spring Top Hat spacers, this effectively shortens the spring travel and keeps the spring in its stiffest part of the stroke. It works well enough for me at 70kg.
    Could be better, but you can pedal this thing hard into mid corner so it feels pretty sorted for road use.
    I've got a USD setup in bits currently, got a set off NOS 1996 YZ250 Forks, if anything, they just look sick.
    I will do a Build thread on installing USD forks for the DTR, as I think many people want to do it but are not sure about the parts needed to do so.
    Re-mounted my Ignitech CDI with rubber mounts and polished up my bracket, sadly it seems the company has disappeared. I've never had a problem with my unit and this Programmable CDI is the best thing I ever bought for this project.
    The spark on this thing is ridiculously good.
    I couldn't be bothered to fix my ported 3MB 'P' 134cc Cylinder so i went back to my old 14,000 Mile standard bore 3MB
    Cylinder with a TDR unrestricted Head, and it has been so much fun to ride. Just a torqueey reliable DT engine like I remember it when I was 17.
    QUICK ENOUGH LOL
    Been running different carbs for a few years now, and I have to say you couldnt do much better than well Setup Mikuni TM28ss and the 30ss from a WR200 is brilliant for the 125R.., depending on how good you can setup the floats and mixture.
    This is the problem with any carburettor using the standard Inlet,
    MIKUNI TM28SS - TM30SS - TM32 - TM34SS - KEIHIN PWK36
    My favourite so far has been setting up a Mikuni TM34SS from a Aprilia RS250 and Later model RGV250s, (Same engine)
    Mainly, the Venturi is angled so the Fuel Bowl remains level. But it has a really effective power jet and has been easy to setup, it works really well with just 125cc, this engine barks and pulls great at Mid-Range too. For me, I pretty happy keeping this engine under 140cc. It's plenty fun.
    I'm using a Modified WR200 Inlet with Boyseen DT200R Reeds. Runs good.
    I have a 3D printed Airbox to Carb boot I designed, so it's water tight and easier to jet than a Pod Filter.
    Currently waiting to print a new filament that has the right Shore Hardness to produce a rubber part like the original. You need a good amount of flex to seat the airbox and carb together.
    This has all been paired with old Nikkon Race exhaust, Handmade, Gas welded steel. There is pretty much no info on these.
    I bought this from a guy who used it a couple of times and then stored it for 10 years, as far as I know this is the only DT125R Nikkon pipe left in existence. Which is a shame, because this pipe is so much better than the DEP on the road.
    I'm going to copy this pipe into Stainless steel and just keep it the way it is because it suites my application so well. Very large expansion pipe aswell, the design is unique.
    Will go further into the restoration of it as it's currently covered in BBQ Black paint.
    Long term project aye, I've already had my fun.
    Louis-DT-WRL
    Louis-DT-WRL
    Louis-DT-WR
    @Darty tm34ss is the perfect upgrade due the the shape and angle, keeps the float bowl level .
    I think there's a tm36ss also
    • PeluriP
      PeluriP
      Peluri
      wrote on last edited by Peluri
      #122
      Hey darty, could you share us the files for your 3D printed intake manifold and airbox thingy?
      • DartyD
        DartyD
        wrote on last edited by Darty
        #123
        Exhaust Porn
        This was the last one ever left, I finally bit the bullet and purchased a Stainless exhaust for the DT.
        This came all the way from bloody Portugal like this πŸ˜‚
        Great job lads.
        Ballin' - This is the 'YAMAHA DT125 Special Exhaust' in STAINLESS DTX DTR-E with end can from Romeu125 an eBay seller.
        Custom design by the gang over there and beautifully hand made.
        Really quite impressed, only ever 4 sold on eBay.
        Looks great, low slung - Interesting design. I've got to say, did not fit that well with the tail pipe supplied. It was so awkward in fact I decided to fit my WR200 FMF tail pipe DIY instead.
        Looks cool, but too raspy for my taste.
        Picked up maybe the last NOS WR200 Mikuni Idle screw ever? This stuff is all getting expensive and stupidly hard to come by these days...
        Airbox
        Next up, finishing up the Airbox. Drilled and bolted up with M5 bolts and importantly using Nylocs. Can't have the ingestion of M5 bolts into the crankcase.
        Got it bang on with a perfect seal, sadly it's no going back with the install but that's the best that can be achieved SLA 3D printing.
        WR200 SideStand - 1991-1993
        The early versions of the WR200 came with a long enduro style kickstand. Almost impossible to find nowadays and I'm kicking myself for not getting one NOS from Fowlers back in the day, but I was a student at the time.
        Due to the design you need to notch the DTR frame, so 'sayonara' fresh powdercoat here and sent it with the Grinder. It looks like I've cut to far there, but it's just swarf.
        Again, NO GOING BACK.
        The WR200 sidestand looks mint, tucks up nicely and props the bike up much further if you run an increased ride height over standard on the DTR.
        (New longer spring needed)
        FINAL FORM
        I'm running DT230 Lanza Frame Guards, Left handside here is a ZETA part. Otherside is an OEM Lanza Part which only fits right handside for the DTR and require spacers and machining to fit the DTR. But worth it.
        HOT BOI
        Such an odd Croissant that pipe....,
        I think that's it for the DTR, It's a beast, sounds great and is still alot of fun 7 years on. But it's had it’s day.
        Is it better? All I'm certain is that it's mine.
          Yeah that's looking lovely mate. It's a lovely looking machine.
          I don't think this is the end for you mate. I reckon you need throw a set of USD forks on there for completeness.
          That would just be πŸ‘Œ Perfect then!
          • PeluriP
            PeluriP
            Peluri
            You should really get some better foot pegs! I think the WR200 ones fit right on.
              I am running Apico KTM ones. Nice and wide.
              PeluriP 1 Reply Last reply
                PeluriP
                PeluriP
                Peluri
                @Calum That's nice, how do the KTM pegs fit the DTR? Any modding needed or bolt-on?
                  I just ground down the ends of them as they wouldn't sit flush. It's a very minor mod I didn't think twice about it.
                    PeluriP
                    PeluriP
                    Peluri
                    @Calum Ok so they fit easily? I'll think about getting myself a pair of those then!
                      Yeah it was simple. I tried looking I could find exactly what I bought. I must have done it after I "finished" my bike and thus didn't document it. But yeah was a really easy mod and now I have Phat footrests.
                        PeluriP
                        PeluriP
                        Peluri
                        @Calum Really nice! My only problem is the budget, those things are like a 100€ 😬 Maybe I should get some Chinesium ones πŸ˜…
                        • PeluriP Peluri
                          @Peluri the Chinese footpegs look nice been meaning to get a set
                            PeluriP
                            PeluriP
                            Peluri
                            @declan Alright, I'll get myself a pair of those! Thanks!
                            • DartyD Darty
                              QUICK ENOUGH LOL
                              finchfockerF
                              finchfockerF
                              finchfocker
                              @Darty what ignitec cdi did you go for?? Ive sent an email and they have recommended the DCCDIP1 race
                              • finchfockerF finchfocker
                                PeluriP
                                PeluriP
                                Peluri
                                @finchfocker I myself just bought the DCCDIP1 race. Seems like a great unit, just programmed myself a ignition map to start off with, hopefully I'll get a chance to plug her in soon!
