  3. Other
  4. Re booting the sm 50 am6 project
24 Posts 5 Posters 7.4k Views 1 Watching
  • declanD
    Here's how we stand the bike leaks coolant not a issue needs new hose clamps - bike only works in firsts and second any other gear and the bike does not ride it moves at walking pace and revs don't climb so I'm looking clutch?-to set off you have to redline the bike and baby the clutch has good power in first and second- leaks oil big time from the clutch actuator arm even though it's got a brand new seal installed correctly so I'm stumped at that.
      @declan Things to do after the above issues are solved- strip all non essential wiring and weight- convert to pre mix - 90cc top end and maybe paint the frame if I can be bothered- any and all input is appreciated any ideas and any answers to the above issues this will be a slow build as money is an issue thank you
        @declan ![0_14981_1498151445067_IMG_0882.JPG 0_1498151550011_IMG_0661.JPG 0_1498151504560_IMG_0857.JPG
        • MightymanM
          MightymanM
          I think these are great looking bikes. I want to pick up a project one someday and stick a 125 engine into it.
          • MightymanM Mightyman
            @Mightyman I wanted a dt engine in it the mounts are nearly the same but just can't afford one
              @declan just stripped all the wires to get rid of clutter and potential broken wires
                @declan @Calum how tight should the seal be around a clutch push rod mines leaking on a new seal and it's not very tight it's seals it but give not resistance sliding down the shaft?
                  @declan make that clearer it's full wrapped around the shaft but it's not a very tight seal what do you think?
                    @declan There should be some resistance bud.
                      @Calum hmmm okay maybe I'll try getting a new one now would you reckon my clutch plates need changing since I lose all power past 2nd gear?
                        @declan You would have to measure their thickness and check it against the specified tolerances
                          @Calum thanks for your time.
                            Fired right up and running good more to follow
                              @Calum i believe that my power problem is severe clutch drag as the lever only has around 2 inches of pull and it's no where near enough
                                @Calum gotta love that sound
                                https://youtu.be/SdjEarivTtM
                                • MightymanM
                                  MightymanM
                                  very nice 👍
                                    very nice 👍
                                    @Mightyman thank you hopefully it actually rides now and if it does there will soon be a nice big bore on it
                                    • DartyD
                                      DartyD
                                      I had a proper Minarelli AM6 CH Racing WXE50 when I was 16.
                                      It had a 12mm Dellorto Carb!! lol
                                      It only did 55mph, but it was the fastest 50cc to get there I've ever known.
                                      I'll always miss this motorcycle...
                                      • DartyD Darty
                                        @Darty mines struggling for power I've now sorted the clutch but it's still struggling not sure what it could be, the carb on this is like. A pea shooter lol
                                        • DartyD Darty
                                          @Darty Pretty sure my RS had a bigger carb than that at 20mm...
                                          declanD 2 Replies Last reply
