PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,)
Got it back together, just need reflector and number plate bracket, ...mirrors on order.
And the tool box is on, balances the rear end with the exhaust silencer nicely.
@calum said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
I must admit, that is looking pucker!
Really great photos as well. What camera are you using?
Thanks mate, my Huawei mate 10 Pro phone .
Really shows the attention to detail. Might take the DT out tomorrow along some trails to get some decent pictures, test ride then get my head down for the big bike test after my holiday next month 😎 spare up some cash -
@irongamer727 said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
@calum and how does he get them inbedded here directly?
If Callum had a pound for every time he was asked this 🤣 there's a tutorial, very simple, just use a good host site like imgur
@louis-james 😛
Slowly getting it to be how I visioned it.
Toning it down, exhaust guard on, chain guard powdercoated black, radiator Louvres changed from yellow ones to gun metal grey.
Just want my mirrors to turn up 😁
Warning stickers on
@Louis-James said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
And ofcourse I had zeeltronic make the first DT125R CDI for me and for all my help I only had to pay for the handheld reprogrammer
This was perfect for my project to set the powervalve limits and curve.
Also great for ignition timing.
Although they did wire it wrong originally and the powervalve ran backwards :laughing:
But soon sorted it.
Hi matie,
What map did you use for the DT200WR top end as I'm starting to build a 125R / 200WR hybrid?Cheers
@Bluestoesonnose hi, I made a custom map
Cheers, any tips for the ignition timing compared to the DT125R, ie, retard or advance over std?
Is it possible to send me a copy of the map as a starter for 10?
@Bluestoesonnose from memory I advanced it 3degree in the lower to mid range
Many thanks
@Bluestoesonnose if I remember I'll get my zeeltronic map copied
Once again, many thanks
