  3. Other
  4. Project SMX [Pic Heavy]
276 Posts 16 Posters 171.2k Views 4 Watching
    @NINJA should make it so when you turn your key it plays that song lol
    @declan Now that would be sooooooooooooooooooooooooooo cool!!! :smiling_face_with_sunglasses: :smiling_face_with_sunglasses: :smiling_face_with_sunglasses:
      @NINJA innovation nation baby!
        wrote on last edited by Darty
        #193
        That polished brake lever should see anywhere from 3-5bhp gained, from experience.
          @Darty Only 3-5 extra horses - DAMN I was hoping for at least 10!!! :grinning_face_with_smiling_eyes: :smiling_face_with_open_mouth_closed_eyes: :winking_face: :face_with_stuck-out_tongue_winking_eye:
          • NINJAN
            #195
            Decisions, decisions;
            Which handguards do you guys reckon look the best???
            declanD pedrobatista10P 2 Replies Last reply
              Acerbis definitely. They suit it down to the tea.
              • stinkwheelerS
                stinkwheelerS
                stinkwheeler
                wrote on last edited by stinkwheeler
                #197
                Yea id say the acerbis ones 👍
                • P
                  P
                  Pablo13
                  Agreed :smiling_face_with_sunglasses:
                    @NINJA acerbis
                      pedrobatista10P
                      pedrobatista10P
                      pedrobatista10
                      @NINJA acerbis look very good!
                      • NINJAN
                        #201
                        Did someone say SuperMoto??? 🏍💨
                        I think that the handguards look Uber Cool and tie in really well with the bike's colour scheme. But the only downside is they provide less room than the Barkbusters, which means I will have to get some shorter levers for my brake and clutch. So I'll have to save up for those ASV lever's I've been drooling over already!!!
                        :smiling_face_with_heart-eyes: :face_blowing_a_kiss: :smiling_face_with_heart-eyes: :face_savouring_delicious_food: :face_savouring_delicious_food: :face_savouring_delicious_food:
                          That is looking super tidy!
                          • NINJAN
                            #203
                            Hy Mec - How you doinggg???
                            She took a bit of setting up and after several bleed's, a full strip down and rebuild of the slave cylinder I have finally got her working. I can't wait to test her out for real, but first impressions is that the clutch is buttery smooth to operate!!! :grinning_face_with_smiling_eyes: :face_with_stuck-out_tongue_winking_eye: :grinning_face_with_smiling_eyes:
                            I had to modify the clutch arm to follow the curve on the clutch case, as the arm would not pull the clutch cam lever properly otherwise and it also stopped the cam lever from retracting back as well;
                            I re-used the OEM clutch cable and cut off the end, as it has a rather nice double oil seal on it. Plus it moves the slave cylinder away from the clutch case, thus providing room for the oil pipes to neatly tuck behind it. I also cut a piece off the plastic protection sleeve and used that to join the slave cylinder to the old clutch cable. I also found a U shaped bracket I had lying around which was nearly a perfect fit to secure the slave cylinder. I just used a longer bolt and added some washers to keep it all secure.
                            After some adjustments I was able to get her working really well, I will only know for-sure once the engine is running and I can test the gear shifting out properly, as the Rotax engine does not seem to like shifting up and down the gears without the engine running. As I had some problems with the grip shift mechanism sticking whilst testing the Hymec. So I had to remove the clutch case and strip the grip shift down, to clean it all up, re-grease it all and reassemble it to stop it sticking. But after much fannying around and tweaking she seems really solid now, but the true test will be with a running engine, so it's TBC..................
                              #204
                              The angled inlet manifold for the 34mm Dellorto carb finally arrived, 3 weeks from Italy via the Donkey express!!!
                              It's designed to fit the stock reed block, so some mods were called for. Once I had cut off the reed flange, I set about port matching it as best I could to the new Italkit Carbon reed block;
                              She's not perfect, but it is lovely and smooth, I feel that it turned out pretty good, so she's all ready for fitting now, along with that shiny 34mm Dellorto carb I purchased some months ago.
                              :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes:
                                yeah that's looking sweet bud!
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  @NINJA loving the attention to detail! Good work!
                                  • Louis-DT-WRL Louis-DT-WR
                                    @Louis-James Thanks man, I'm just following in your footsteps!!! :grinning_face_with_smiling_eyes: :winking_face: :smiling_face_with_open_mouth_closed_eyes: :face_with_stuck-out_tongue_winking_eye: :grinning_face_with_smiling_eyes:
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      @NINJA easy to get carried away but feels good knowing everything is 100%
                                        @Louis-James Peace_of_mind is a wonderful thing for-sure!!! :grinning_face_with_smiling_eyes: :smiling_face_with_sunglasses: 🤗 :smiling_face_with_heart-eyes:
                                        • NINJAN
                                          WOOP WOOP - The airbox upgrades have arrived;
