  4. Dt 125r dyno
Dt 125r dyno
98 Posts 14 Posters 36.4k Views 1 Watching
  • J jonne123
    How tzr 125 makes 25hp?
    NottsbikerN
    NottsbikerN
    @jonne123 said in Dt 125r dyno:
    Different dyno's read differently and also manufacturers often claim at the crank not back wheel 😉
    • J jonne123
      So im simple terms its easier to buy another bike.
      clawsC
      clawsC
      claws
      @jonne123 kyllä noista detseistä tulee se 25 hepoa täystehosena koneelta. tuo 13 hepoa on kuristuksilla. itellä tuli ehkä joku 27-28 ku oli 170cc, giannelli ja 36 millinen keihini
        jonne123
        täytyy käydä toisessa penkissä ja huomaa että ei ollu pakoaukon säädin oikein kun ei penkissä menny edes 10000rpm.
        O clawsC 2 Replies Last reply
        • J jonne123
          @jonne123 absolutely, couldn't agree more!
          • O oldman
            @oldman Actung! Sprich Englisch!
              jonne123
              just Finnish... very easy to understand
              • J jonne123
                clawsC
                clawsC
                claws
                @jonne123 ootko johtokikan teheny?
                J 1 Reply Last reply
                • clawsC claws
                  jonne123
                  @claws said in Dt 125r dyno:
                  Its a 1994 model
                    Genuinely, Brits are so lazy, the fact you guys can just switch between both of the languages is incredible. And to be fair, your English is better than people I know. English is a frustrating language too! So hats off to you 😛
                      I can do French though!
                      CalumC NottsbikerN 2 Replies Last reply
                      • O oldman
                        @oldman Good news, when I want to surrender I'll give you a shout!
                          Stevie WonderS
                          Stevie WonderS
                          Stevie Wonder
                          @Calum said in Dt 125r dyno:
                          You can’t shout at someone when they’ve already been invaded
                            jonne123
                            Well many technical stuff is in english so its must to know terms and also i have learned english since i was 9. I also watch lot of English videos.
                            • O oldman
                              NottsbikerN
                              NottsbikerN
                              wrote on last edited by Nottsbiker
                              #80
                              @oldman said in Dt 125r dyno:
                              When I buy a place over there I'll get in touch for help
                              Surprised you havent started up a business like Unit 5 or Franek importing DT's 😉
                                jonne123
                                If the zeeltronic is worth it. Do i need anything else besides the box? Should i take the bike to dyno adjustment. Is there any ready maps that i just plug computer and install?
                                O 1 Reply Last reply
                                • J jonne123
                                  @jonne123 all the info you want is already on the site. Take some time to search for it and it's all there buddy 👍
                                    As Oldman says, I've said it a thousand times before and I'm only saying it again because I'm back at my computer.
                                    Yes, IMO (and that is just my opinion) the zeeltronic ignition system was the biggest bang for buck performance in my eyes. Separate from you lot that can "easily achieve" 30hp out of the DTR engine. If you're like me and not that clever with porting or tuning, then the zeel will do fabulous wonders to the mid range and red line. It's also future proofing your modifications as you start to tune the engine you will be able to alter the ignition timing.
                                    Zeeltronic provide 5 base maps and you will want the Hand held programmer to change them.
                                    It's not a USB interface, so at minimum you would need the Serial to USB converter. Again, all this is described on their website.
                                      jonne123
                                      does it come with the pv maps too? also does it have wiring diagram?
                                      And what are the benefits beside little more power and future proofing.
                                      • J jonne123
                                        @jonne123 as stated the info you are looking for is either on this site or on zeels site
                                        • J jonne123
                                          @jonne123 More torque, better fuel economy.
                                          No I don't think there were any powervalve maps. But that's simple enough to figure out.
