  4. Dt 125r dyno
Dt 125r dyno
98 Posts 14 Posters 36.4k Views 1 Watching
    I can do French though!
    CalumC NottsbikerN 2 Replies Last reply
    • O oldman
      @oldman Good news, when I want to surrender I'll give you a shout!
        Stevie WonderS
        Stevie WonderS
        Stevie Wonder
        @Calum said in Dt 125r dyno:
        You can’t shout at someone when they’ve already been invaded
          jonne123
          Well many technical stuff is in english so its must to know terms and also i have learned english since i was 9. I also watch lot of English videos.
          • O oldman
            NottsbikerN
            NottsbikerN
            wrote on last edited by Nottsbiker
            #80
            @oldman said in Dt 125r dyno:
            When I buy a place over there I'll get in touch for help
            Surprised you havent started up a business like Unit 5 or Franek importing DT's 😉
              jonne123
              If the zeeltronic is worth it. Do i need anything else besides the box? Should i take the bike to dyno adjustment. Is there any ready maps that i just plug computer and install?
              O 1 Reply Last reply
              • J jonne123
                @jonne123 all the info you want is already on the site. Take some time to search for it and it's all there buddy 👍
                  As Oldman says, I've said it a thousand times before and I'm only saying it again because I'm back at my computer.
                  Yes, IMO (and that is just my opinion) the zeeltronic ignition system was the biggest bang for buck performance in my eyes. Separate from you lot that can "easily achieve" 30hp out of the DTR engine. If you're like me and not that clever with porting or tuning, then the zeel will do fabulous wonders to the mid range and red line. It's also future proofing your modifications as you start to tune the engine you will be able to alter the ignition timing.
                  Zeeltronic provide 5 base maps and you will want the Hand held programmer to change them.
                  It's not a USB interface, so at minimum you would need the Serial to USB converter. Again, all this is described on their website.
                    jonne123
                    does it come with the pv maps too? also does it have wiring diagram?
                    And what are the benefits beside little more power and future proofing.
                    • J jonne123
                      @jonne123 as stated the info you are looking for is either on this site or on zeels site
                      • J jonne123
                        @jonne123 More torque, better fuel economy.
                        No I don't think there were any powervalve maps. But that's simple enough to figure out.
                          jonne123
                          #87
                          • programmable power valve actuation
                          • store and load function for 5 PV curves
                          • programmable PV deviation
                          • programmable max close and max open positions
                          • self PV test on power-up
                          • PV error detecting (position sensor failure, servo motor failure)
                          https://www.zeeltronic.com/page/pcdi-10v.php
                          also there is connectors sold do i need to buy or are they like regular 1 wire to 1 wire in the bike?
                          does it come with handheld programmer or do i need to buy it seperately im confused.
                            Mine came with the right plug
                            Programmer sold separately
                            A 1 Reply Last reply
                              A
                              A
                              Arild
                              One question, is the handheld programmer needed? Would u be able to just plug it in to a laptop instead with adapters etc?
                                I don't know, I think they have a Windows application
                                  jonne123
                                  i want to know if i need to buy those connectors.
                                    Then ask them
                                    • J jonne123
                                      @jonne123 I bought the usb/laptop lead when I bought my zeel. Very easy to use once you have it installed.
                                      • J jonne123
                                        Well true. but what is realistic top speed from dtr
                                        A
                                        A
                                        Anditover
                                        @jonne123
                                        My stock 2002 DT125R does a genuine, GPS verified 82mph. The speedo needle actually goes all the way to the edge of the clock, on a good day.
                                        The only mod is moving, NOT cutting the "Reed switch" that plugs into the back of the speedo.
                                        It appears to detect (by magnetism) when the speedo passes 65mph and retards the ignition. Move it out of the way, and voilà! No longer restricted!
                                        Use super unleaded and always warm the engine up before thrashing.
                                        • A
                                          A
                                          Anditover
