1.1k Posts 26 Posters 685.9k Views
    No one used this kinda gasket?
    Given my experiences recently I’m wary of fitting it even though it’s new & Athena...
    @spookdog I always use Athena gaskets. RS/Cagiva/Yamaha
      #85
      Took me a while but I got a rebore and new piston. Almost got it back together.
      I ended up getting another gasket, single layer usual thing. I just didn’t trust the triple ply one held together with brass rivets! A single bit of crap between one of the layers would be fatal. Theyre fairly loose but uncleanable on the 4 inner surfaces!...
      I’d love to know why Athena makes it...
        @spookdog Never had an issue with Athena gaskets myself.
          #87
          @spookdog I think you are overthinking the headgasket a bit mate athena make some of the best non oem gaskets and seals
            I know they make good gaskets, but this thing is over 3 times the thickness of a ‘normal’ one. I’d just like to know why. There must be a good reason!...
            Also my bike is ticking over nice and low but when I put the lights on it stumbles and dies. Any input? I have the first stator with three individual coils. 1 for charching 1 for lights and 1 for ignition. How can the lights be piggy backing the ignition?! Poor earth on the ignition side?
              @spookdog id imagine it's a crush gasket so when it's torqued down it would crush down to oem thickness and seal really well
                @spookdog Same thing happens in my Starlet. If I turn the headlights on and fans on the idle drops 🤣
                  Done my first running in run. 65 miles of ‘still going’!
                  Fingers crossed 🤞
                    Fingers crossed 🤞
                    @spookdog
                    500 miles run in
                    • declanD
                      @spookdog noice
                        @spookdog
                        500 miles run in
                        #94
                        @spookdog
                        I just got a 400 Kenda rear tyre. Am I going to regret it? Does the Dtr take a 400 tyre ok?
                          @spookdog
                          Anyone used rust converter on exhaust downpipe?...
                          R NottsbikerN Stevie WonderS markus.wM 4 Replies Last reply
                            R
                            R
                            rollzy101
                            @spookdog if its rust converter mine burnt and pealed off, ended up using acid based rust remover which was fine
                            Owned: Yamaha DT125LC, XT125, DT125R, YZF R125, CBR125, RS125
                              NottsbikerN
                              NottsbikerN
                              @spookdog I've used the Loctite stuff before but its not very good, apparently Jennolite (sp?) is meant to be much better. Probably better to get blasted then paint immediately afterwards
                                Stevie WonderS
                                Stevie WonderS
                                Stevie Wonder
                                @spookdog said in So Close!...:
                                Use harpic x10, a few of my mates use it on their WR125’s to get all the road grim that builds up and allow the pipe to bronze a nice colour however I’ve been told it’s known to strip stainless of its stainless ability so I’d also recommend getting your hands on some ACF50
                                  NottsbikerN
                                  NottsbikerN
                                  @stevie-wonder Harpic is brutal but effective - it will mark the chrome on forks its that acidic. If you use it you must paint straight after as its bare metal which will immediately rust again
                                  • NottsbikerN Nottsbiker
                                    Cheers guys!
                                      @spookdog I used Hammerite kurust on my Dep downpipe that had rusted really bad at the header. It's a brush on rust converter that transforms the rust into a stable material. It turns it black then you paint it. Done at the start of this year and all good so far. £5 from Halfords.
                                        Stevie WonderS
                                        Stevie WonderS
                                        Stevie Wonder
                                        #102
                                        @markus-w said in So Close!...:
                                        Pretty sure hammerite also do a gel rust converter, simply apply, let it’s do it’s thing then get to going at it with some good old fashion elbow grease. £15 I think (bit pricey) perfectly safe on paint and being the fact it’s a gel it’s rather ideal for leaving on in those hard to reach areas and fiddly bits
                                        Also @Nottsbiker jheez. strong stuff then, I’m surprised it’s sold so freely over the counter if that’s the case
                                          NottsbikerN
                                          NottsbikerN
                                          @stevie-wonder its good for the price, you just have to be careful and only use it on the right parts
