  4. Took head off after breakdown
33 Posts 7 Posters 10.4k Views
  • ZrakoZ Zrako
    @Calum what exactly does that plug chop is ? Never heard that before
    @Zrako http://kawtriple.com/mraxl/carb/plugchop.htm
    https://www.google.co.uk/search?q=plug+chop&ie=utf-8&oe=utf-8&client=firefox-b-ab&gfe_rd=cr&ei=1eVrWaveI6fA8gf04rnACA
    Google my friend.
    ZrakoZ 1 Reply Last reply
      Google my friend.
      ZrakoZ
      ZrakoZ
      Zrako
      @Calum whoa . I need to get some standard plugs then . Thanks for help again
      1979 Jawa Mustang 50
      2003 Gilera DNA 125 R.I.P
      2015 Keeway TX 125 SM
      2006 Yamaha DT 125 X
      • ZrakoZ Zrako
        @Zrako my bikes clog up on idle give it a nice few revs to clear it out
        • MightymanM
          Wow I have never actually read this up before. Always assumed a "plug chop" was running the bike for couple minutes, then visually inspecting the plug. Seems like a lot of effort / plug money to get it running perfect, but obviously worth it. Nothing better than a 2 stroke motor purring over perfectly. 👍
            @Mightyman and you know what they say about assumptions.
            Oh my bad, seriously I thought it was common knowledge.
            • ZrakoZ
              ZrakoZ
              Zrako
              Completed the bike again 100% , 10 minutes warm up , took it on the street . Hardly powerband , valve moving properly but struggled . Tried to go between the gears hardly 3rd only sometimes . Impossible to shift , only with heel 😑. Took it apart again and tried to figure out whats going on. I think this is the problem.
              https://youtu.be/xqXsdSxaTwQ
              I think the sping is slacked. Found picture in the haynes
              Did anyone experienced something like this?
              • A
                A
                andrewj1680
                My spring doesnt come up through the holes like yours does, the legs sit underneath the same as it does in the Haynes manual image
                • ZrakoZ
                  ZrakoZ
                  Zrako
                  Cant find the spring for sale . Just the new shaft 😓
                  • A
                    A
                    andrewj1680
                    I dont think you need a new spring you need to push the feet of the spring back through, the spring is pretty slack on all ive seen but not had any gear selection problems
                    • A
                      A
                      andrewj1680
                      0_1500416320929_20170718_231423.jpg 0_1500416356105_20170718_231411.jpg 0_1500416380228_20170718_231253.jpg 0_1500416405701_20170718_231238.jpg
                      • A
                        A
                        andrewj1680
                        Worse case its only £41+vat complete new
