  4. Took head off after breakdown
33 Posts 7 Posters 10.4k Views
  • ZrakoZ
    ZrakoZ
    Zrako
    Well , here we go again . 2nd rebuild . Now with new crank bearings and seals 🙄 , new piston and rings , new - used clutch , removed kickstart and got new used stay for the sprag clutch and installed starter motor, fresh gear oil.
    https://youtu.be/b2MZ359Ag3g
    Here is what it sounds like . First start was surprisingly smooth ,was idling bit higher so turned it down and bled autolube . Feel strange as it was maybe too good to be true lol .
    Let me know what you think about the sound. Havent jump on it yet btw.
    1979 Jawa Mustang 50
    2003 Gilera DNA 125 R.I.P
    2015 Keeway TX 125 SM
    2006 Yamaha DT 125 X
    • ZrakoZ Zrako
      @Zrako Sounds like a 4 stroke with the airbox lid off. LOL
      Great job tho!!! 👍
      • ZrakoZ
        ZrakoZ
        Zrako
        Well , brand new iridium br9eix after like 30 minutes idling. First 5 minutes was bleeding oil pump. Doesnt smoke too much . 🤕
        • ZrakoZ Zrako
          @Zrako A bit rich, but you won't really tell unless you do a plug chop.
          • ZrakoZ
            ZrakoZ
            Zrako
            @Calum what exactly does that plug chop is ? Never heard that before
            • ZrakoZ Zrako
              @Zrako http://kawtriple.com/mraxl/carb/plugchop.htm
              https://www.google.co.uk/search?q=plug+chop&ie=utf-8&oe=utf-8&client=firefox-b-ab&gfe_rd=cr&ei=1eVrWaveI6fA8gf04rnACA
              Google my friend.
              ZrakoZ 1 Reply Last reply
                Google my friend.
                ZrakoZ
                ZrakoZ
                Zrako
                @Calum whoa . I need to get some standard plugs then . Thanks for help again
                • ZrakoZ Zrako
                  @Zrako my bikes clog up on idle give it a nice few revs to clear it out
                  • MightymanM
                    Wow I have never actually read this up before. Always assumed a "plug chop" was running the bike for couple minutes, then visually inspecting the plug. Seems like a lot of effort / plug money to get it running perfect, but obviously worth it. Nothing better than a 2 stroke motor purring over perfectly. 👍
                      @Mightyman and you know what they say about assumptions.
                      Oh my bad, seriously I thought it was common knowledge.
                      • ZrakoZ
                        ZrakoZ
                        Zrako
                        Completed the bike again 100% , 10 minutes warm up , took it on the street . Hardly powerband , valve moving properly but struggled . Tried to go between the gears hardly 3rd only sometimes . Impossible to shift , only with heel 😑. Took it apart again and tried to figure out whats going on. I think this is the problem.
                        https://youtu.be/xqXsdSxaTwQ
                        I think the sping is slacked. Found picture in the haynes
                        Did anyone experienced something like this?
                        • A
                          A
                          andrewj1680
                          My spring doesnt come up through the holes like yours does, the legs sit underneath the same as it does in the Haynes manual image
                          • ZrakoZ
                            ZrakoZ
                            Zrako
                            Cant find the spring for sale . Just the new shaft 😓
                            • A
                              A
                              andrewj1680
                              I dont think you need a new spring you need to push the feet of the spring back through, the spring is pretty slack on all ive seen but not had any gear selection problems
                              • A
                                A
                                andrewj1680
                                0_1500416320929_20170718_231423.jpg 0_1500416356105_20170718_231411.jpg 0_1500416380228_20170718_231253.jpg 0_1500416405701_20170718_231238.jpg
                                • A
                                  A
                                  andrewj1680
                                  Worse case its only £41+vat complete new
