PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,)
@cyber-ninja https://youtu.be/KGIQr68yHpc
@louis-james Per-ting, per-ting VROOM, VROOM, VROOOMMMMM, VROOOOMMMMMMMMMMMMMMMMMMMMM!!!
Looks and sounds awesome mate - top job!!!
@declan thanks guys. Normally revs out higher and smoother but fuels a bit old,
Like the headlight guard! Looks very hardcore
@nottsbiker cheers, going for the tenere look
Yes I can tell, especially with the XT / 200R mudguard with additional spoiler.
Cant see pics as they are blocked at work but from the video looks like you've done a very good job mate
@nottsbiker it's photobucket holding me to ransom that's blocking the pictures
Maybe but our servers block the avatars etc anyways so hard to say from here
[[topic:post-is-deleted]]
You are going to need the embed link mate.
You need the URL of the image, not the web address it can be found at.
Easiest way, just use Imgur.
@calum thanks callum, I tried imgur but apparently it's not supporting 3rd party hosting for much longer or its a rumour,
Someone mentioned a cloud button, I don't know what that it,
I'll keep trying until it works -
@louis-james The polishing on your exhaust pipe is extremely disappointing bud.
I can't see your face in the reflection, please fix this ASAP - Thanks!!!
LOLLLZZZZZZZZZZZZZZZZZZZ
@cyber-ninja I know, but it's the plating from new! It's always been like that, especially on that part of the front pipe
@oldman said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
Good work, satisfying innit! How many hours have you put in?
Thank you, about 7years haha, on and off.
Interesting you went with the DEP pipe as I'd have thought the FMF one from the WR would have suited your cylinder better. Any particular reason for this choice?
I'll keep trying until it works@louis-james this GIF should show you how to use the little cloud button I mentioned. It actually uses Imgur but simplifies the process for everyone here. I haven't heard of them cancelling 3rd party support but it would be very frustrating for us and many others if they do.
Note that if you are on mobile, you may need to swipe left on the editing tools to see it!
