tuningdtryamaha2003wr200
254 Posts 25 Posters 237.3k Views 6 Watching
  • NottsbikerN
    NottsbikerN
    Like the headlight guard! Looks very hardcore 🙂
    • NottsbikerN Nottsbiker
      Louis-DT-WRL
      Louis-DT-WRL
      @nottsbiker cheers, going for the tenere look 😉
      • NottsbikerN
        NottsbikerN
        Yes I can tell, especially with the XT / 200R mudguard with additional spoiler.
        Cant see pics as they are blocked at work but from the video looks like you've done a very good job mate 🙂
          Louis-DT-WRL
          Louis-DT-WRL
          @nottsbiker it's photobucket holding me to ransom that's blocking the pictures
          • NottsbikerN
            NottsbikerN
            Maybe but our servers block the avatars etc anyways so hard to say from here
              @Louis-James you made that headlight guard right?
                Louis-DT-WRL
                Louis-DT-WRL
                #208
                  alt
                  You are going to need the embed link mate.
                  You need the URL of the image, not the web address it can be found at.
                  Easiest way, just use Imgur.
                  • Louis-DT-WRL Louis-DT-WR
                    [[topic:post-is-deleted]]
                    #210
                    @louis-james The polishing on your exhaust pipe is extremely disappointing bud.
                    I can't see your face in the reflection, please fix this ASAP - Thanks!!! 😉
                    LOLLLZZZZZZZZZZZZZZZZZZZ
                      Good work, satisfying innit! How many hours have you put in?
                        alt
                        Louis-DT-WRL
                        Louis-DT-WRL
                        @calum thanks callum, I tried imgur but apparently it's not supporting 3rd party hosting for much longer or its a rumour,
                        Someone mentioned a cloud button, I don't know what that it,
                        I'll keep trying until it works
                          Louis-DT-WRL
                          Louis-DT-WRL
                          @cyber-ninja I know, but it's the plating from new! It's always been like that, especially on that part of the front pipe
                          • O oldman
                            Louis-DT-WRL
                            Louis-DT-WRL
                            @oldman said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
                            Thank you, about 7years haha, on and off.
                            • NottsbikerN
                              NottsbikerN
                              Interesting you went with the DEP pipe as I'd have thought the FMF one from the WR would have suited your cylinder better. Any particular reason for this choice?
                                #216
                                @louis-james this GIF should show you how to use the little cloud button I mentioned. It actually uses Imgur but simplifies the process for everyone here. I haven't heard of them cancelling 3rd party support but it would be very frustrating for us and many others if they do.
                                Note that if you are on mobile, you may need to swipe left on the editing tools to see it!
                                  @louis-james Literally wrote a blog on this. Take the time to read and understand it as it's really not that technical.
                                    Louis-DT-WRL
                                    Louis-DT-WRL
                                    #218
                                    @nottsbiker I did consider the FMF but I saw a thread where someone put one on a Dt200r and it was close to the rad scoops and didn't want melt them, also the DEP were UK stock.
                                    • Louis-DT-WRL
                                      Louis-DT-WRL
                                      #219
                                      Got the hang of it now. I will "repair" some of my broken images
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        https://youtu.be/apMFEINtbQU
                                        • Louis-DT-WRL
                                          Louis-DT-WRL
                                          ![alt text](Dt125r https://imgur.com/gallery/Xc38LJ4)
                                          I Got bored and decided to have a OCD moment and fit a seat strap, front fender rear extension to match the tenere theme, rebuilt the fuel cap with parts from my original cap to use original key(same as ignition), new indicator relay, mounted the zeeltronic using a p clip and frame bracket and used nutserts for a proper job, new chain guard.
                                          I'm also fitting a underseat tool box like the French bikes have for an old school feel.
                                          I'm mostly logging this for my own benefit as these mods probably seem boring now haha.
                                          But I'm really considering installing the original numberplate holder/tail light, any thoughts?
                                          Just want an old school feel.
                                          F 1 Reply Last reply
