  4. TDR issue
TDR issue
97 Posts 12 Posters 35.0k Views 1 Watching
  • NottsbikerN
    NottsbikerN
    Have you checked the markings on the oil pump all line up correctly?
    Good choice of bike btw 🙂
    T 1 Reply Last reply
    • NottsbikerN Nottsbiker
      T
      T
      TDRnoob
      @nottsbiker It was a really old dream to get a 90s enduro like DT or TDR. 🙂 Happy, but I need to learn more about those 2 strokes. As I want to fix by myself. There is a video with my oil pump. Oil pump seems lined up correctly?
      https://www.youtube.com/watch?v=OlMfqiuIErA
        Mybelgarda oil pump failed and couldn't be adjusted. It just rinsed oil.
        I went premix in the end.
        T 2 Replies Last reply
          Right crank seal?
            T
            T
            TDRnoob
            wrote on last edited by TDRnoob
            @calum So you just removed all 2 stroke oil from the tank and started to use premix?
            • J Jens Eskildsen
              Right crank seal?
              T
              T
              TDRnoob
              @jens-eskildsen not sure. I need to investigate. And how to do that? Full engine rebuild?
                I did because the adjustments didn't seem to do anything. Never had any problems with my plugs mind you. Maybe I caught it before it got really bad.
                • T TDRnoob
                  NottsbikerN
                  NottsbikerN
                  @tdrnoob said in TDR issue:
                  Not quite but it is easy to blank off the injection system properly and you can even buy plates to cover the missing oil pump. If i remember correctly you also need to up jet by something like 5% to allow for the oil being in the fuel.
                  • T TDRnoob
                    NottsbikerN
                    NottsbikerN
                    Yes you'd have to strip the motor right down for those kind of checks but you could do a rebuild for maybe less than £500 including mains, crank, piston and rebore. This is a bit of a guess and with you doing the work yourself.
                    If you remember to loosen the clutch nut whilst the engine is in the bike you only need a flywheel puller to strip the motor down. If you want to save the crank and not have to rebuild then a set of casing splitters would be a good idea but you can make these as well.
                    • NottsbikerN
                      NottsbikerN
                      Not sure if it is just the video but your bike looks like it's in reasonable condition with the body work all complete. Mines in bits now awaiting a full rebuild as it looked like it had come from Afghanistan not Italy when i got it home.
                        T
                        T
                        TDRnoob
                        @nottsbiker Thanks for advise. I have done top end rebuild with newly refurbished cylinder kit from Germany. Had a feeling that it is still something not right.
                          T
                          T
                          TDRnoob
                          @nottsbiker It came from France. About 25000 km on the clock.
                            That looks lovely.
                            • NottsbikerN
                              NottsbikerN
                              wrote on last edited by Nottsbiker
                              Only thing that looks wrong with the TDR compared to the DTR is how low the back end sits. I think that the shock is either shorter or the dog bones are different.
                              Bike looks great btw 🙂
                                @nottsbiker that's beatiful I haven't seen a tdr that I truly like but that one is it
                                • NottsbikerN
                                  NottsbikerN
                                  Yeah sorry dude that was a general comment not aimed at noobs TDR.
                                    • 1 vote for red 😁
                                      T
                                      T
                                      TDRnoob
                                      @nottsbiker I was trying to search for these plates. Where did you see it? Could you please send me the link how it looks like.
                                      • NottsbikerN
                                        NottsbikerN
                                        What plates are you on about? Do you mean the Jack up plates then I think it's either DTR shock or links (dog bones) to raise the rear end
                                          T
                                          T
                                          TDRnoob
                                          @nottsbiker to cover the missing oil pump
