  4. TDR issue
TDR issue
97 Posts 12 Posters 35.0k Views 1 Watching
    Mybelgarda oil pump failed and couldn't be adjusted. It just rinsed oil.
    I went premix in the end.
    T
    T
    TDRnoob
    wrote on last edited by TDRnoob
    @calum So you just removed all 2 stroke oil from the tank and started to use premix?
    • J Jens Eskildsen
      Right crank seal?
      T
      T
      TDRnoob
      @jens-eskildsen not sure. I need to investigate. And how to do that? Full engine rebuild?
        I did because the adjustments didn't seem to do anything. Never had any problems with my plugs mind you. Maybe I caught it before it got really bad.
        • T TDRnoob
          NottsbikerN
          NottsbikerN
          @tdrnoob said in TDR issue:
          Not quite but it is easy to blank off the injection system properly and you can even buy plates to cover the missing oil pump. If i remember correctly you also need to up jet by something like 5% to allow for the oil being in the fuel.
          T 1 Reply Last reply
          • T TDRnoob
            NottsbikerN
            NottsbikerN
            Yes you'd have to strip the motor right down for those kind of checks but you could do a rebuild for maybe less than £500 including mains, crank, piston and rebore. This is a bit of a guess and with you doing the work yourself.
            If you remember to loosen the clutch nut whilst the engine is in the bike you only need a flywheel puller to strip the motor down. If you want to save the crank and not have to rebuild then a set of casing splitters would be a good idea but you can make these as well.
            • NottsbikerN
              NottsbikerN
              Not sure if it is just the video but your bike looks like it's in reasonable condition with the body work all complete. Mines in bits now awaiting a full rebuild as it looked like it had come from Afghanistan not Italy when i got it home.
              • NottsbikerN Nottsbiker
                T
                T
                TDRnoob
                @nottsbiker Thanks for advise. I have done top end rebuild with newly refurbished cylinder kit from Germany. Had a feeling that it is still something not right.
                  T
                  T
                  TDRnoob
                  @nottsbiker It came from France. About 25000 km on the clock.
                    That looks lovely.
                    • NottsbikerN
                      NottsbikerN
                      wrote on last edited by Nottsbiker
                      Only thing that looks wrong with the TDR compared to the DTR is how low the back end sits. I think that the shock is either shorter or the dog bones are different.
                      Bike looks great btw 🙂
                        @nottsbiker that's beatiful I haven't seen a tdr that I truly like but that one is it
                        • NottsbikerN
                          NottsbikerN
                          Yeah sorry dude that was a general comment not aimed at noobs TDR.
                            • 1 vote for red 😁
                              T
                              T
                              TDRnoob
                              @nottsbiker I was trying to search for these plates. Where did you see it? Could you please send me the link how it looks like.
                              • NottsbikerN
                                NottsbikerN
                                What plates are you on about? Do you mean the Jack up plates then I think it's either DTR shock or links (dog bones) to raise the rear end
                                  T
                                  T
                                  TDRnoob
                                  @nottsbiker to cover the missing oil pump
                                  • NottsbikerN
                                    NottsbikerN
                                    Ah sorry i misunderstood
                                    They come fitted to the WR200 as standard or you can buy them on ebay with this item number
                                    192262337902
                                      192262337902
                                      T
                                      T
                                      TDRnoob
                                      @nottsbiker Thanks
                                      • NottsbikerN
                                        NottsbikerN
                                        No problem dude
                                          T
                                          T
                                          TDRnoob
                                          @calum Hi. Did you change jetting after when you went for premix? If changed then could you remember what sizes for pilot jet and main jet. Thank you
