  4. TDR issue
TDR issue
97 Posts 12 Posters 31.2k Views 1 Watching
  • J Jens Eskildsen
    Right crank seal?
    T Offline
    T Offline
    TDRnoob
    @jens-eskildsen not sure. I need to investigate. And how to do that? Full engine rebuild?
      I did because the adjustments didn't seem to do anything. Never had any problems with my plugs mind you. Maybe I caught it before it got really bad.
      • T TDRnoob
        @calum So you just removed all 2 stroke oil from the tank and started to use premix?
        NottsbikerN Offline
        NottsbikerN Offline
        @tdrnoob said in TDR issue:
        Not quite but it is easy to blank off the injection system properly and you can even buy plates to cover the missing oil pump. If i remember correctly you also need to up jet by something like 5% to allow for the oil being in the fuel.
        T 1 Reply Last reply
        • T TDRnoob
          NottsbikerN Offline
          NottsbikerN Offline
          Yes you'd have to strip the motor right down for those kind of checks but you could do a rebuild for maybe less than £500 including mains, crank, piston and rebore. This is a bit of a guess and with you doing the work yourself.
          If you remember to loosen the clutch nut whilst the engine is in the bike you only need a flywheel puller to strip the motor down. If you want to save the crank and not have to rebuild then a set of casing splitters would be a good idea but you can make these as well.
          • NottsbikerN Offline
            NottsbikerN Offline
            Not sure if it is just the video but your bike looks like it's in reasonable condition with the body work all complete. Mines in bits now awaiting a full rebuild as it looked like it had come from Afghanistan not Italy when i got it home.
            • NottsbikerN Nottsbiker
              T Offline
              T Offline
              TDRnoob
              @nottsbiker Thanks for advise. I have done top end rebuild with newly refurbished cylinder kit from Germany. Had a feeling that it is still something not right.
                T Offline
                T Offline
                TDRnoob
                @nottsbiker It came from France. About 25000 km on the clock.
                  That looks lovely.
                    NottsbikerN Offline
                    wrote on last edited by Nottsbiker
                    Only thing that looks wrong with the TDR compared to the DTR is how low the back end sits. I think that the shock is either shorter or the dog bones are different.
                    Bike looks great btw 🙂
                      @nottsbiker that's beatiful I haven't seen a tdr that I truly like but that one is it
                        NottsbikerN Offline
                        Yeah sorry dude that was a general comment not aimed at noobs TDR.
                        • O Offline
                          O Offline
                          • 1 vote for red 😁
                            T Offline
                            T Offline
                            TDRnoob
                            @nottsbiker I was trying to search for these plates. Where did you see it? Could you please send me the link how it looks like.
                              NottsbikerN Offline
                              What plates are you on about? Do you mean the Jack up plates then I think it's either DTR shock or links (dog bones) to raise the rear end
                                T Offline
                                T Offline
                                TDRnoob
                                @nottsbiker to cover the missing oil pump
                                  NottsbikerN Offline
                                  Ah sorry i misunderstood
                                  They come fitted to the WR200 as standard or you can buy them on ebay with this item number
                                  192262337902
                                    192262337902
                                    T Offline
                                    T Offline
                                    TDRnoob
                                    @nottsbiker Thanks
                                      NottsbikerN Offline
                                      No problem dude
                                        Mybelgarda oil pump failed and couldn't be adjusted. It just rinsed oil.
                                        I went premix in the end.
                                        T Offline
                                        T Offline
                                        TDRnoob
                                        @calum Hi. Did you change jetting after when you went for premix? If changed then could you remember what sizes for pilot jet and main jet. Thank you
                                        • T TDRnoob
                                          @tdrnoob I ran a completely different carburetor, so all my jet sizes would have been changed.
                                          Plus I ran far from standard settings. Jetting must done to suit the machine you are riding, no two machines are the same so jetting is best done to accommodate this.
