  3. Top End
  4. Athena 170
Athena 170
112 Posts 14 Posters 62.5k Views
    @irongamer727 That's what you want mate.
    https://www.ebay.co.uk/itm/YAMAHA-TZR-125-4DL-yr-92-CARBURETTOR-DELLORTO-VHSA-32-GS/282744266127?hash=item41d4df1d8f:g:GTwAAOSwrhhaFTOk
    That'll fix your problem guaranteed!
    I literally don't know why the original carb sucks balls lol.
    @calum I’d rathet bump start it than pay that price lol
      @declan Yeah but that's just the cost of tuning for you bud.
        @calum cost of genuine carbs tbh carbs are quite pricey
        • Irongamer727I
          Irongamer727I
          Things are not going my way. 180km into break in I spotted 2 small holes on the cylinder. I have spoken to the company I bought the kit from and they will contact Athena for assistance. Hopefully this ends well..
          https://youtu.be/JSdh4gz1p8w
          • Irongamer727I
            Irongamer727I
            What do you think? I've now fitted a 310 main jet and she's still a bit down on power. It felt better than the 290 for sure. Now I'm thinking about buying a couple of extra jets, 320-350.
            Is this even possible? I've not spoken to anyone running higher than 280.
            • 2
              2stroketerry
              If using a TM28 carb then need a 300 main jet with a 27.5 idle jet. Main jets go up to 430. Put clip in the bottom groove on needle.
              https://www.sip-scootershop.com/en/products/main+jet+mikuni+300+_40703000
              https://www.sip-scootershop.com/en/products/idle+jet+mikuni+275+_40726000
              • 2 2stroketerry
                Irongamer727I
                Irongamer727I
                @2stroketerry I'm running 310 now and it's certainly not optimal. Idle is 35 now, definitely too big.
                • Irongamer727I
                  Irongamer727I
                  In reality, what would cause the bike not to start on the first or second spin on the starter. Is it just down to the pilot jet and fuel/Air mix?
                  Obviously a good battery and fresh electric components will make things easier but I got that covered.
                  I've read in the Haynes that there is supposed to be a starter jet in the later carbs? Much of what that books says makes no sense...
                  • Louis-DT-WRL
                    Louis-DT-WRL
                    Louis-DT-WR
                    I run the autolube on my dt125r bottom end with wr200 top end. I just adjusted it to suit the larger capacity. I've run it for years. Autolube is brilliant
                    • Louis-DT-WRL Louis-DT-WR
                      Irongamer727I
                      Irongamer727I
                      wrote on last edited by Irongamer727
                      #70
                      @louis-james hows that thing to start?
                      • Louis-DT-WRL
                        Louis-DT-WRL
                        Louis-DT-WR
                        First kick 99% of the time
                          Irongamer727I
                          Irongamer727I
                          @louis-james you run the 28mm carb? The flat one?
                          • Louis-DT-WRL
                            Louis-DT-WRL
                            Louis-DT-WR
                            I used to, I had the tmx30 for a while, now a tm34ss
                              Irongamer727I
                              Irongamer727I
                              @louis-james you ran the 28 with the wr200?
                              • Louis-DT-WRL
                                Louis-DT-WRL
                                Louis-DT-WR
                                No, I had the 30 when it was still a 125. Lid was cut off the air box the the 28mm btw
                                  Irongamer727I
                                  Irongamer727I
                                  @louis-james alright
                                  • Irongamer727I Irongamer727
                                    Louis-DT-WRL
                                    Louis-DT-WRL
                                    Louis-DT-WR
                                    @irongamer727 recommend getting a decent reed block on there. Many can be modified to fit
                                      Irongamer727I
                                      Irongamer727I
                                      @louis-james naah at the moment I simply want her to run good, start easy and stay that way.
                                      • Irongamer727I
                                        Irongamer727I
                                        #79
                                        As I suspected my pilot jet to be too big (size 35) I ordered a smaller 25. But the bike literally ran like shit and the idle was very uncontrolled and the bike just sounded wrong!
                                        Is the next step to order a larger?
                                        I can without a drop in rpm turn the airscrew all the way in, no change really.
                                        That must be an indicator that it's to small right?
                                          Jens Eskildsen
                                          Yeb sounds like you need to up the idlejet in size.
