  4. PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,)
tuningdtryamaha2003wr200
254 Posts 25 Posters 239.7k Views 6 Watching
  • smudge1995S smudge1995
    That bike is a piece of art!!! Fairplay dude thats one of the best dt's I've seen
    Louis-DT-WRL
    Louis-DT-WRL
    Louis-DT-WR
    @smudge1995 thank you very much
      Is looking sweet!
      How did you get on with the car in the end.
      Louis-DT-WRL
      Louis-DT-WRL
      Louis-DT-WR
      This post is deleted!
      • Louis-DT-WRL Louis-DT-WR
        [[topic:post-is-deleted]]
        @Louis-James You need to embed them but.
        There is a tutorial on here if you're unsure.
          Louis-DT-WRL
          Louis-DT-WRL
          Louis-DT-WR
            @Louis-James Yes but I am no longer using that plugin anymore since everytime I upgrade the forum I have to remember what plugins I installed and it was annoying me so I stopped. Ask cyberninja how many times I forget the flipping emoticons lmao
              Louis-DT-WRL
              Louis-DT-WRL
              Louis-DT-WR
                @Louis-James As said there is a guide on here how to do it, it's straightforward nothing complex about it.
                  Louis-DT-WRL
                  Louis-DT-WRL
                  Louis-DT-WR
                    @Louis-James It's up to you, it's your build thread, display the information however you want.
                    I'm sure my build has got more photos than yours and I managed alright. It's something I took pride in.
                    One thing I did was move all of the photos off the first post, so that the page can load and then you can load the photos later. But I sort by latest post. I also moved all the build pictures into one post so it was just a continuous blog.
                    But each to their own.
                    DartyD 1 Reply Last reply
                      DartyD
                      DartyD
                      wrote on last edited by Darty
                      #110
                      @Calum Just to butt in a sec,
                      I've noticed my Flickr links are not embedded anymore, and wont do so..
                      I will have to go through and re link every one from a different hosting site?
                      • DartyD Darty
                        @Darty No they probably just need embedding properly.
                        • Louis-DT-WRL
                          Louis-DT-WRL
                          Louis-DT-WR
                          wrote on last edited by Louis-DT-WR
                          #112
                          Got a few small but satisfying jobs to do.
                          Fit the 17t front sprocket to gear up.
                          Fit stronger clutch springs (uprated wr200 ones)
                          Coolant and oil change.
                          Custom thicker core alloy radiator.
                          Replace LH crank case cover with a silver one to match.
                          General fine tune and visual tweeks.
                          I have it on the bench next to a standard one with a spare sub frame bracket. Bottom hose connector needs repositioning. Mounting brackets need welding on and also for the guard
                          • Louis-DT-WRL
                            Louis-DT-WRL
                            Louis-DT-WR
                            #113
                            Starting the fabrication, sits very nicely in the sub frame. Removed hose connections and prepped new ones to be welded on (and weld the big hole)
                            Then I'll fabricate new brackets to take the old rubber mounts. Also checked the clearance for when it's on the bike. Should be plenty room before hits the fuel tank.
                            Fabricated the two mounting brackets. Jigged it up using the subframe to ensure it's not going to rub. It will be free floating on the rubber mounts as it should.
                              @Louis-James This ought to make a nice difference in cooling!
                              Just for anyone else wondering a single ally rad is going to be much more performant than twin iron rads.
                              Just have to be careful not to cool the engine by too much else you'll heat seize the engine on long runs.
                              • Louis-DT-WRL
                                Louis-DT-WRL
                                Louis-DT-WR
                                Hopefully @Calum, still was running alright on my standard radiator for the wr200 motor even though it has 2 as standard.
                                What do you mean by iron? Who would fit that? Would be heavy as.
                                  @Louis-James Stock brass or steel or whatever the original radiators are made from. I know on cars they tend to be brass.
                                  On the Starlets you can get way with running a radiator half the size if it's an ally one as it dissapates heat so much better.
                                    Louis-DT-WRL
                                    Louis-DT-WRL
                                    Louis-DT-WR
                                    Also to note, this core may be 10mm shorter but has 11 cooling tubes and not 8. Also 20mm thicker
                                    • MightymanM
                                      MightymanM
                                      Love these sort of mods. Very well engineered upgrade right there 👍
                                      • MightymanM Mightyman
                                        Louis-DT-WRL
                                        Louis-DT-WRL
                                        Louis-DT-WR
                                        @Mightyman cheers. I like to get things done 🙂
                                        • ZrakoZ
                                          ZrakoZ
                                          Zrako
                                          Looks awesome. Cant wait to see it finished.
                                          1979 Jawa Mustang 50
                                          2003 Gilera DNA 125 R.I.P
                                          2015 Keeway TX 125 SM
                                          2006 Yamaha DT 125 X
