  4. Pv actions
Pv actions
39 Posts 5 Posters 6.2k Views
    @irongamer727 maybe it’s my eyes but that pv looks way out to me
    Irongamer727I
    Irongamer727I
    @declan ye it's spot on mate
    • Irongamer727I
      Irongamer727I
      Anyone care to have a look at the pv video? Is it supposed to move and vibrate that much?
      • Irongamer727I Irongamer727
        @irongamer727 Looks like exhaust gases are leaking past the rubber oring from the bush.
        That are the bush is excessively worn and needs replacing.
          Irongamer727I
          Irongamer727I
          @calum probably since it's 500 km from brand new
          • Irongamer727I
            Irongamer727I
            It shouldn't be vibrating like so then?
              @irongamer727 I've not seen that before no. You will wear the mechanism out like that.
              • MiniaM
                MiniaM
                Minia
                Is the powervalve supposed to open at a set amount of revs? Mine opens just over 6k.
                  Jens Eskildsen
                  Sounds right with 6k
                  • Irongamer727I
                    Irongamer727I
                    Has anyone noticed that their bike is a lot louder with the valve pinned? Noticed I BIG difference on mine
                      @irongamer727 Yeah, the valve muffles the exhaust sound, when you pin it, you're blaring the combustion through the expansion chamber.
                        @irongamer727 mine seemed to idle a lot healthier pinned
                          Irongamer727I
                          Irongamer727I
                          @calum https://youtu.be/TWuDiIHVv4o
                          What do you think might be causing it to be that loose? Everything, even the screw holding the pv sides together is securely fasten.
                          • Irongamer727I
                            Irongamer727I
                            It's leaking oil and even exhaust gases..
                              Yeah, it'll be down on performance if that's the case.
                              Are you sure the other side of the powervalve is fastened properly?
                                Irongamer727I
                                Irongamer727I
                                @calum yes. Fasten it extra today
                                  Irongamer727I
                                  Irongamer727I
                                  @irongamer727 there's play between the pv and the cylinder. Is that normal?
                                    @irongamer727 No
                                      @irongamer727 No
                                      Irongamer727I
                                      Irongamer727I
                                      @calum ideas? Just another thing to complain about to Athena?
                                        @irongamer727 I’d say so yes
